02-19-2011, 09:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Where Dreams Become Realit Age: 28
Member: 645436 Status: Offline Thanks Meter: 1,501 | Plese help me nokia 1600 SW Version: V 7.02 10-12-07 RH-64 (c) NMP Imei plain: 35838300752597-3 Product Code: 0525458 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Imei net: 35838300752597 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D8F56A:2984DA60 ASIC type: 2 UEM Imei: 35838300752597 Flash Imei: 35838300752597 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35838300752597_BA CK.rpl" Processing MCU file: rh64_07.020 [DCT4,DCT4 ALGORITHM] size: 1.84 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D8F56A:2984DA60 Area [01000000-0100FFFF] erased in 0.484 s Area [01010000-013BFFFF] erased in 27.687 s Area [013C0000-013EFFFF] erased in 1.391 s Area [017C0000-017EFFFF] erased in 0.093 s Area [01FC0000-01FEFFFF] erased in 0.094 s Flash programming ... Programming completed in 11.094 s File Processed in 49.985 s Processing CNT file: rh640_nai7.02ia [DCT4,DCT4 ALGORITHM] size: 139.00 KB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D8F56A:2984DA60 Area [01380000-013BFFFF] erased in 1.937 s Flash programming ... Programming completed in 0.875 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.313 s File Processed in 18.890 s Processing PPM file: rh64_07.02ia [DCT4,DCT4 ALGORITHM] size: 1.42 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D8F56A:2984DA60 Area [011D0000-011DFFFF] erased in 0.500 s Area [011E0000-0137FFFF] erased in 12.281 s Flash programming ... Programming completed in 8.562 s File Processed in 32.609 s Total time for flashing process(boot+erase+write) was 1 min 41.500 s Phone Type: RH-64 SW Version: V 7.02 10-12-07 RH-64 (c) NMP Imei plain: 35838300752597-3 Product Code: 0525458 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Imei net: 35838300752597 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN only nokia ............................. |
02-19-2011, 09:23 | #5 (permalink) |
Member: 645436 Status: Offline Thanks Meter: 1,501 | MCU SW : V 7.02 10-12-07 RH-64 (c) NMP PPM SW : V 7.02 10-12-07 RH-64 (c) NMP IA Prd.Code: 0525458 Bpr.Code: 0520754 Prod.Sn : KJL338352 HW Vers : 0502 UEM : 1314 UPP : 8705 [2201] RFIC Ver: DSP Vers: LCD Type: SEID:NAXvA0 S31 IMEI : 358383-00-752597-3 SL Conf : 001-01-00000000000 SL Prof : 000000000000000-2 SL Var : 00003583830075259700 SL Aux : 00020000 HW Sig : 046E6A5C0396583E Box Id : 894F894FFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN MastCode: 43 75 74 22 26 Provider: GSM Test Equipment #pw+ 837 001 155 552 712 +1# #pw+ 292 845 213 040 550 +2# #pw+ 486 807 204 410 411 +3# #pw+ 936 302 553 445 011 +4# #pw+ 903 962 027 141 776 +5# #pw+ 956 532 776 457 144 +6# #pw+ 345 596 461 337 405 +7# 1st Boot: Ok, DCT4, UPP: 2201 [Rh-64] [2.1.0.0] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: u_amd.fia, Ver: 4.79.0 Area1: 0x01000000-0x013FFFFF Erased, Time: 00:32 1st Boot: Ok, DCT4, UPP: 2201 [Rh-64] [2.1.0.0] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: u_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 8482DEA642537333D16BEEAAD0 Decoded MSID: 3E4EBAE9-00D8F56A-A9000000 Encoded FAID: D8723800-D0FDCF82-2950A9FA IMAGE: rh64_03.060 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013BFFFF Erased, Time: 00:30 Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:01 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:10 IMAGE: rh640_nai3.06ia Area1: 0x01380000-0x013BFFFF Erased, Time: 00:02 CNT Flashing Completed, Time: 00:00 Running: Server fake reply for CUI phone. Contents Package Extracting Ok, Time: 00:07 1st Boot: Ok, DCT4, UPP: 2201 [Rh-64] [2.1.0.0] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: u_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 84E6E6B61F8248274A682FB7A5 Decoded MSID: 3E4EBAE9-00D8F56A-A8000000 Encoded FAID: 1417D1FA-7804C279-F73A4AAD IMAGE: rh64_03.06ia Area1: 0x011C0000-0x011CFFFF Erased, Time: 00:00 Area2: 0x011D0000-0x0137FFFF Erased, Time: 00:14 PPM Flashing Completed, Time: 00:09 Flashing Completed, Rebooting Mobile PM File: Rh-64_358639013863728.pm Group Id: [1] Rec: 0 Len: 120 .... Ok 2 Group Id: [1] Rec: 2 Len: 90 ..... Ok 1 Group Id: [1] Rec: 4 Len: 110 .... Ok 2 Group Id: [1] Rec: 5 Len: 2 ...... Ok 1 Group Id: [1] Rec: 6 Len: 90 ..... Ok 1 Group Id: [1] Rec: 11 Len: 2 ...... Ok 1 Group Id: [1] Rec: 12 Len: 2 ...... Ok 1 Group Id: [2] Rec: 0 Len: 132 .... Ok 2 Group Id: [3] Rec: 0 Len: 3 ...... Ok 1 Group Id: [4] Rec: 0 Len: 1 ...... Ok 1 Group Id: [4] Rec: 1 Len: 8 ...... Ok 1 Group Id: [4] Rec: 2 Len: 44 ..... Ok 1 Group Id: [4] Rec: 3 Len: 10 ..... Ok 1 Group Id: [4] Rec: 4 Len: 8 ...... Ok 1 Group Id: [4] Rec: 5 Len: 8 ...... Ok 1 Group Id: [4] Rec: 6 Len: 8 ...... Ok 1 Group Id: [4] Rec: 9 Len: 5 ...... Ok 1 Group Id: [5] Rec: 0 Len: 78 ..... Ok 1 Group Id: [7] Rec: 0 Len: 4 ...... Ok 1 Group Id: [7] Rec: 1 Len: 32 ..... Ok 1 Group Id: [7] Rec: 2 Len: 4 ...... Ok 1 Group Id: [8] Rec: 0 Len: 12 ..... Ok 1 Group Id: [11] Rec: 0 Len: 4 ...... Ok 1 Group Id: [11] Rec: 1 Len: 4 ...... Ok 1 Group Id: [11] Rec: 2 Len: 4 ...... Ok 1 Group Id: [11] Rec: 3 Len: 4 ...... Ok 1 Group Id: [11] Rec: 4 Len: 1 ...... Ok 1 Group Id: [11] Rec: 5 Len: 6 ...... Ok 1 Group Id: [11] Rec: 6 Len: 4 ...... Ok 1 Group Id: [11] Rec: 7 Len: 2 ...... Ok 1 Group Id: [11] Rec: 8 Len: 1 ...... Ok 1 Group Id: [11] Rec: 9 Len: 4 ...... Ok 1 Group Id: [11] Rec: 10 Len: 31 ..... Ok 1 Group Id: [11] Rec: 11 Len: 2 ...... Ok 1 Group Id: [11] Rec: 12 Len: 1 ...... Ok 1 Group Id: [11] Rec: 13 Len: 1 ...... Ok 1 Group Id: [11] Rec: 14 Len: 1 ...... Ok 1 Group Id: [11] Rec: 15 Len: 1 ...... Ok 1 Group Id: [11] Rec: 16 Len: 8 ...... Ok 1 Group Id: [11] Rec: 17 Len: 1 ...... Ok 1 Group Id: [11] Rec: 18 Len: 1 ...... Ok 1 Group Id: [11] Rec: 19 Len: 4 ...... Ok 1 Group Id: [11] Rec: 20 Len: 2 ...... Ok 1 Group Id: [11] Rec: 21 Len: 2 ...... Ok 1 Group Id: [11] Rec: 22 Len: 1 ...... Ok 1 Group Id: [11] Rec: 23 Len: 8 ...... Ok 1 Group Id: [11] Rec: 24 Len: 1 ...... Ok 1 Group Id: [11] Rec: 25 Len: 2 ...... Ok 1 Group Id: [11] Rec: 26 Len: 2 ...... Ok 1 Group Id: [11] Rec: 27 Len: 2 ...... Ok 1 Group Id: [11] Rec: 28 Len: 2 ...... Ok 1 Group Id: [11] Rec: 29 Len: 2 ...... Ok 1 Group Id: [11] Rec: 30 Len: 4 ...... Ok 1 Group Id: [11] Rec: 31 Len: 4 ...... Ok 1 Group Id: [11] Rec: 32 Len: 4 ...... Ok 1 Group Id: [11] Rec: 33 Len: 4 ...... Ok 1 Group Id: [11] Rec: 34 Len: 4 ...... Ok 1 Group Id: [11] Rec: 35 Len: 4 ...... Ok 1 Group Id: [11] Rec: 36 Len: 16 ..... Ok 1 Group Id: [11] Rec: 37 Len: 4 ...... Ok 1 Group Id: [11] Rec: 38 Len: 2 ...... Ok 1 Group Id: [11] Rec: 39 Len: 4 ...... Ok 1 Group Id: [11] Rec: 40 Len: 2 ...... Ok 1 Group Id: [11] Rec: 41 Len: 2 ...... Ok 1 Group Id: [11] Rec: 42 Len: 1 ...... Ok 1 Group Id: [11] Rec: 43 Len: 1 ...... Ok 1 Group Id: [11] Rec: 44 Len: 4 ...... Ok 1 Group Id: [11] Rec: 45 Len: 4 ...... Ok 1 Group Id: [11] Rec: 46 Len: 4 ...... Ok 1 Group Id: [11] Rec: 47 Len: 4 ...... Ok 1 Group Id: [11] Rec: 48 Len: 4 ...... Ok 1 Group Id: [11] Rec: 49 Len: 4 ...... Ok 1 Group Id: [11] Rec: 50 Len: 4 ...... Ok 1 Group Id: [11] Rec: 51 Len: 4 ...... Ok 1 Group Id: [11] Rec: 52 Len: 4 ...... Ok 1 Group Id: [11] Rec: 53 Len: 4 ...... Ok 1 Group Id: [11] Rec: 54 Len: 4 ...... Ok 1 Group Id: [11] Rec: 55 Len: 4 ...... Ok 1 Group Id: [11] Rec: 56 Len: 4 ...... Ok 1 Group Id: [11] Rec: 57 Len: 4 ...... Ok 1 Group Id: [11] Rec: 58 Len: 4 ...... Ok 1 Group Id: [11] Rec: 59 Len: 4 ...... Ok 1 Group Id: [11] Rec: 60 Len: 4 ...... Ok 1 Group Id: [11] Rec: 61 Len: 4 ...... Ok 1 Group Id: [11] Rec: 62 Len: 4 ...... Ok 1 Group Id: [11] Rec: 63 Len: 4 ...... Ok 1 Group Id: [11] Rec: 64 Len: 4 ...... Ok 1 Group Id: [11] Rec: 65 Len: 4 ...... Ok 1 Group Id: [11] Rec: 66 Len: 4 ...... Ok 1 Group Id: [11] Rec: 67 Len: 4 ...... Ok 1 Group Id: [11] Rec: 68 Len: 4 ...... Ok 1 Group Id: [11] Rec: 69 Len: 4 ...... Ok 1 Group Id: [11] Rec: 70 Len: 4 ...... Ok 1 Group Id: [11] Rec: 71 Len: 4 ...... Ok 1 Group Id: [11] Rec: 72 Len: 4 ...... Ok 1 Group Id: [11] Rec: 73 Len: 4 ...... Ok 1 Group Id: [11] Rec: 74 Len: 4 ...... Ok 1 Group Id: [11] Rec: 75 Len: 4 ...... Ok 1 Group Id: [11] Rec: 76 Len: 4 ...... Ok 1 Group Id: [11] Rec: 77 Len: 4 ...... Ok 1 Group Id: [11] Rec: 78 Len: 4 ...... Ok 1 Group Id: [11] Rec: 79 Len: 4 ...... Ok 1 Group Id: [11] Rec: 80 Len: 4 ...... Ok 1 Group Id: [11] Rec: 81 Len: 4 ...... Ok 1 Group Id: [11] Rec: 82 Len: 2 ...... Ok 1 Group Id: [11] Rec: 83 Len: 4 ...... Ok 1 Group Id: [11] Rec: 84 Len: 2 ...... Ok 1 Group Id: [11] Rec: 85 Len: 1 ...... Ok 1 Group Id: [11] Rec: 86 Len: 16 ..... Ok 1 Group Id: [11] Rec: 87 Len: 88 ..... Ok 1 Group Id: [11] Rec: 88 Len: 2 ...... Ok 1 Group Id: [11] Rec: 89 Len: 4 ...... Ok 1 Group Id: [11] Rec: 90 Len: 2 ...... Ok 1 Group Id: [11] Rec: 91 Len: 2 ...... Ok 1 Group Id: [11] Rec: 92 Len: 2 ...... Ok 1 Group Id: [11] Rec: 93 Len: 2 ...... Ok 1 Group Id: [11] Rec: 94 Len: 2 ...... Ok 1 Group Id: [11] Rec: 95 Len: 2 ...... Ok 1 Group Id: [11] Rec: 96 Len: 2 ...... Ok 1 Group Id: [11] Rec: 97 Len: 2 ...... Ok 1 Group Id: [11] Rec: 98 Len: 2 ...... Ok 1 Group Id: [11] Rec: 99 Len: 2 ...... Ok 1 Group Id: [11] Rec: 100 Len: 2 ...... Ok 1 Group Id: [11] Rec: 101 Len: 2 ...... Ok 1 Group Id: [11] Rec: 102 Len: 2 ...... Ok 1 Group Id: [11] Rec: 103 Len: 2 ...... Ok 1 Group Id: [11] Rec: 104 Len: 2 ...... Ok 1 Group Id: [11] Rec: 105 Len: 2 ...... Ok 1 Group Id: [11] Rec: 106 Len: 2 ...... Ok 1 Group Id: [11] Rec: 107 Len: 2 ...... Ok 1 Group Id: [11] Rec: 108 Len: 2 ...... Ok 1 Group Id: [11] Rec: 109 Len: 2 ...... Ok 1 Group Id: [11] Rec: 110 Len: 2 ...... Ok 1 Group Id: [11] Rec: 111 Len: 2 ...... Ok 1 Group Id: [11] Rec: 112 Len: 2 ...... Ok 1 Group Id: [11] Rec: 113 Len: 2 ...... Ok 1 Group Id: [11] Rec: 114 Len: 2 ...... Ok 1 Group Id: [13] Rec: 0 Len: 34 ..... Ok 1 Group Id: [13] Rec: 1 Len: 34 ..... Ok 1 Group Id: [13] Rec: 2 Len: 34 ..... Ok 1 Group Id: [13] Rec: 3 Len: 34 ..... Ok 1 Group Id: [13] Rec: 4 Len: 34 ..... Ok 1 Group Id: [13] Rec: 5 Len: 34 ..... Ok 1 Group Id: [13] Rec: 6 Len: 34 ..... Ok 1 Group Id: [13] Rec: 7 Len: 34 ..... Ok 1 Group Id: [13] Rec: 8 Len: 34 ..... Ok 1 Group Id: [13] Rec: 9 Len: 34 ..... Ok 1 Group Id: [13] Rec: 10 Len: 34 ..... Ok 1 Group Id: [13] Rec: 11 Len: 34 ..... Ok 1 Group Id: [13] Rec: 12 Len: 34 ..... Ok 1 Group Id: [13] Rec: 13 Len: 34 ..... Ok 1 Group Id: [13] Rec: 14 Len: 34 ..... Ok 1 Group Id: [13] Rec: 15 Len: 34 ..... Ok 1 Group Id: [13] Rec: 16 Len: 34 ..... Ok 1 Group Id: [13] Rec: 17 Len: 34 ..... Ok 1 Group Id: [13] Rec: 18 Len: 34 ..... Ok 1 Group Id: [13] Rec: 19 Len: 34 ..... Ok 1 Group Id: [13] Rec: 20 Len: 34 ..... Ok 1 Group Id: [13] Rec: 21 Len: 34 ..... Ok 1 Group Id: [13] Rec: 22 Len: 34 ..... Ok 1 Group Id: [13] Rec: 23 Len: 34 ..... Ok 1 Group Id: [13] Rec: 24 Len: 34 ..... Ok 1 Group Id: [13] Rec: 25 Len: 34 ..... Ok 1 Group Id: [13] Rec: 26 Len: 34 ..... Ok 1 Group Id: [13] Rec: 27 Len: 34 ..... Ok 1 Group Id: [13] Rec: 28 Len: 34 ..... Ok 1 Group Id: [13] Rec: 29 Len: 34 ..... Ok 1 Group Id: [13] Rec: 30 Len: 34 ..... Ok 1 Group Id: [13] Rec: 31 Len: 34 ..... Ok 1 Group Id: [13] Rec: 32 Len: 34 ..... Ok 1 Group Id: [13] Rec: 33 Len: 34 ..... Ok 1 Group Id: [13] Rec: 34 Len: 34 ..... Ok 1 Group Id: [13] Rec: 35 Len: 34 ..... Ok 1 Group Id: [13] Rec: 36 Len: 34 ..... Ok 1 Group Id: [13] Rec: 37 Len: 34 ..... Ok 1 Group Id: [13] Rec: 38 Len: 34 ..... Ok 1 Group Id: [13] Rec: 39 Len: 34 ..... Ok 1 Group Id: [13] Rec: 40 Len: 34 ..... Ok 1 Group Id: [13] Rec: 41 Len: 34 ..... Ok 1 Group Id: [13] Rec: 42 Len: 34 ..... Ok 1 Group Id: [13] Rec: 43 Len: 34 ..... Ok 1 Group Id: [13] Rec: 44 Len: 34 ..... Ok 1 Group Id: [13] Rec: 45 Len: 34 ..... Ok 1 Group Id: [13] Rec: 46 Len: 34 ..... Ok 1 Group Id: [13] Rec: 47 Len: 34 ..... Ok 1 Group Id: [13] Rec: 48 Len: 34 ..... Ok 1 Group Id: [13] Rec: 49 Len: 34 ..... Ok 1 Group Id: [13] Rec: 50 Len: 34 ..... Ok 1 Group Id: [13] Rec: 51 Len: 34 ..... Ok 1 Group Id: [13] Rec: 52 Len: 34 ..... Ok 1 Group Id: [13] Rec: 53 Len: 34 ..... Ok 1 Group Id: [13] Rec: 54 Len: 34 ..... Ok 1 Group Id: [13] Rec: 55 Len: 34 ..... Ok 1 Group Id: [13] Rec: 56 Len: 34 ..... Ok 1 Group Id: [13] Rec: 57 Len: 34 ..... Ok 1 Group Id: [13] Rec: 58 Len: 34 ..... Ok 1 Group Id: [13] Rec: 59 Len: 34 ..... Ok 1 Group Id: [13] Rec: 60 Len: 34 ..... Ok 1 Group Id: [13] Rec: 61 Len: 34 ..... Ok 1 Group Id: [13] Rec: 62 Len: 34 ..... Ok 1 Group Id: [13] Rec: 63 Len: 34 ..... Ok 1 Group Id: [13] Rec: 64 Len: 34 ..... Ok 1 Group Id: [13] Rec: 65 Len: 34 ..... Ok 1 Group Id: [13] Rec: 66 Len: 34 ..... Ok 1 Group Id: [13] Rec: 67 Len: 34 ..... Ok 1 Group Id: [13] Rec: 68 Len: 34 ..... Ok 1 Group Id: [13] Rec: 69 Len: 34 ..... Ok 1 Group Id: [13] Rec: 70 Len: 34 ..... Ok 1 Group Id: [13] Rec: 71 Len: 34 ..... Ok 1 Group Id: [13] Rec: 72 Len: 34 ..... Ok 1 Group Id: [13] Rec: 73 Len: 34 ..... Ok 1 Group Id: [13] Rec: 74 Len: 34 ..... Ok 1 Group Id: [13] Rec: 75 Len: 34 ..... Ok 1 Group Id: [13] Rec: 76 Len: 34 ..... Ok 1 Group Id: [13] Rec: 77 Len: 34 ..... Ok 1 Group Id: [13] Rec: 78 Len: 34 ..... Ok 1 Group Id: [13] Rec: 79 Len: 34 ..... Ok 1 Group Id: [13] Rec: 80 Len: 34 ..... Ok 1 Group Id: [13] Rec: 81 Len: 34 ..... Ok 1 Group Id: [13] Rec: 82 Len: 34 ..... Ok 1 Group Id: [13] Rec: 83 Len: 34 ..... Ok 1 Group Id: [13] Rec: 84 Len: 34 ..... Ok 1 Group Id: [13] Rec: 85 Len: 34 ..... Ok 1 Group Id: [13] Rec: 86 Len: 34 ..... Ok 1 Group Id: [13] Rec: 87 Len: 34 ..... Ok 1 Group Id: [13] Rec: 88 Len: 34 ..... Ok 1 Group Id: [13] Rec: 89 Len: 34 ..... Ok 1 Group Id: [13] Rec: 90 Len: 34 ..... Ok 1 Group Id: [13] Rec: 91 Len: 34 ..... Ok 1 Group Id: [13] Rec: 92 Len: 34 ..... Ok 1 Group Id: [13] Rec: 93 Len: 34 ..... Ok 1 Group Id: [13] Rec: 94 Len: 34 ..... Ok 1 Group Id: [13] Rec: 95 Len: 34 ..... Ok 1 Group Id: [13] Rec: 96 Len: 34 ..... Ok 1 Group Id: [13] Rec: 97 Len: 34 ..... Ok 1 Group Id: [13] Rec: 98 Len: 34 ..... Ok 1 Group Id: [13] Rec: 99 Len: 34 ..... Ok 1 Group Id: [13] Rec: 100 Len: 34 ..... Ok 1 Group Id: [13] Rec: 101 Len: 34 ..... Ok 1 Group Id: [13] Rec: 102 Len: 34 ..... Ok 1 Group Id: [13] Rec: 103 Len: 34 ..... Ok 1 Group Id: [13] Rec: 104 Len: 34 ..... Ok 1 Group Id: [13] Rec: 105 Len: 34 ..... Ok 1 Group Id: [13] Rec: 106 Len: 34 ..... Ok 1 Group Id: [13] Rec: 107 Len: 34 ..... Ok 1 Group Id: [13] Rec: 108 Len: 34 ..... Ok 1 Group Id: [13] Rec: 109 Len: 34 ..... Ok 1 Group Id: [13] Rec: 110 Len: 34 ..... Ok 1 Group Id: [13] Rec: 111 Len: 34 ..... Ok 1 Group Id: [13] Rec: 112 Len: 34 ..... Ok 1 Group Id: [13] Rec: 113 Len: 34 ..... Ok 1 Group Id: [13] Rec: 114 Len: 34 ..... Ok 1 Group Id: [13] Rec: 115 Len: 34 ..... Ok 1 Group Id: [13] Rec: 116 Len: 34 ..... Ok 1 Group Id: [13] Rec: 117 Len: 34 ..... Ok 1 Group Id: [13] Rec: 118 Len: 34 ..... Ok 1 Group Id: [13] Rec: 119 Len: 34 ..... Ok 1 Group Id: [13] Rec: 120 Len: 34 ..... Ok 1 Group Id: [13] Rec: 121 Len: 34 ..... Ok 1 Group Id: [13] Rec: 122 Len: 34 ..... Ok 1 Group Id: [13] Rec: 123 Len: 34 ..... Ok 1 Group Id: [13] Rec: 124 Len: 34 ..... Ok 1 Group Id: [13] Rec: 125 Len: 34 ..... Ok 1 Group Id: [13] Rec: 126 Len: 34 ..... Ok 1 Group Id: [13] Rec: 127 Len: 34 ..... Ok 1 Group Id: [13] Rec: 128 Len: 34 ..... Ok 1 Group Id: [13] Rec: 129 Len: 34 ..... Ok 1 Group Id: [13] Rec: 130 Len: 34 ..... Ok 1 Group Id: [13] Rec: 131 Len: 34 ..... Ok 1 Group Id: [13] Rec: 132 Len: 34 ..... Ok 1 Group Id: [13] Rec: 133 Len: 34 ..... Ok 1 Group Id: [13] Rec: 134 Len: 34 ..... Ok 1 Group Id: [13] Rec: 135 Len: 34 ..... Ok 1 Group Id: [13] Rec: 136 Len: 34 ..... Ok 1 Group Id: [13] Rec: 137 Len: 34 ..... Ok 1 Group Id: [13] Rec: 138 Len: 34 ..... Ok 1 Group Id: [13] Rec: 139 Len: 34 ..... Ok 1 Group Id: [13] Rec: 140 Len: 34 ..... Ok 1 Group Id: [13] Rec: 141 Len: 34 ..... Ok 1 Group Id: [13] Rec: 142 Len: 34 ..... Ok 1 Group Id: [13] Rec: 143 Len: 34 ..... Ok 1 Group Id: [13] Rec: 144 Len: 34 ..... Ok 1 Group Id: [13] Rec: 145 Len: 34 ..... Ok 1 Group Id: [13] Rec: 146 Len: 34 ..... Ok 1 Group Id: [13] Rec: 147 Len: 34 ..... Ok 1 Group Id: [13] Rec: 148 Len: 34 ..... Ok 1 Group Id: [13] Rec: 149 Len: 34 ..... Ok 1 Group Id: [13] Rec: 150 Len: 34 ..... Ok 1 Group Id: [13] Rec: 151 Len: 34 ..... Ok 1 Group Id: [13] Rec: 152 Len: 34 ..... Ok 1 Group Id: [13] Rec: 153 Len: 34 ..... Ok 1 Group Id: [13] Rec: 154 Len: 34 ..... Ok 1 Group Id: [13] Rec: 155 Len: 34 ..... Ok 1 Group Id: [13] Rec: 156 Len: 34 ..... Ok 1 Group Id: [13] Rec: 157 Len: 34 ..... Ok 1 Group Id: [13] Rec: 158 Len: 34 ..... Ok 1 Group Id: [13] Rec: 159 Len: 34 ..... Ok 1 Group Id: [13] Rec: 160 Len: 34 ..... Ok 1 Group Id: [13] Rec: 161 Len: 34 ..... Ok 1 Group Id: [13] Rec: 162 Len: 34 ..... Ok 1 Group Id: [13] Rec: 163 Len: 34 ..... Ok 1 Group Id: [13] Rec: 164 Len: 34 ..... Ok 1 Group Id: [13] Rec: 165 Len: 34 ..... Ok 1 Group Id: [13] Rec: 166 Len: 34 ..... Ok 1 Group Id: [13] Rec: 167 Len: 34 ..... Ok 1 Group Id: [13] Rec: 168 Len: 34 ..... Ok 1 Group Id: [13] Rec: 169 Len: 34 ..... Ok 1 Group Id: [13] Rec: 170 Len: 34 ..... Ok 1 Group Id: [13] Rec: 171 Len: 34 ..... Ok 1 Group Id: [13] Rec: 172 Len: 34 ..... Ok 1 Group Id: [13] Rec: 173 Len: 34 ..... Ok 1 Group Id: [13] Rec: 174 Len: 34 ..... Ok 1 Group Id: [13] Rec: 175 Len: 34 ..... Ok 1 Group Id: [13] Rec: 176 Len: 34 ..... Ok 1 Group Id: [13] Rec: 177 Len: 34 ..... Ok 1 Group Id: [13] Rec: 178 Len: 34 ..... Ok 1 Group Id: [13] Rec: 179 Len: 34 ..... Ok 1 Group Id: [13] Rec: 180 Len: 34 ..... Ok 1 Group Id: [13] Rec: 181 Len: 34 ..... Ok 1 Group Id: [13] Rec: 182 Len: 34 ..... Ok 1 Group Id: [13] Rec: 183 Len: 34 ..... Ok 1 Group Id: [13] Rec: 184 Len: 34 ..... Ok 1 Group Id: [13] Rec: 185 Len: 34 ..... Ok 1 Group Id: [13] Rec: 186 Len: 34 ..... Ok 1 Group Id: [13] Rec: 187 Len: 34 ..... Ok 1 Group Id: [13] Rec: 188 Len: 34 ..... Ok 1 Group Id: [13] Rec: 189 Len: 34 ..... Ok 1 Group Id: [13] Rec: 190 Len: 34 ..... Ok 1 Group Id: [13] Rec: 191 Len: 34 ..... Ok 1 Group Id: [13] Rec: 192 Len: 34 ..... Ok 1 Group Id: [13] Rec: 193 Len: 34 ..... Ok 1 Group Id: [13] Rec: 194 Len: 34 ..... Ok 1 Group Id: [13] Rec: 195 Len: 34 ..... Ok 1 Group Id: [13] Rec: 196 Len: 34 ..... Ok 1 Group Id: [13] Rec: 197 Len: 34 ..... Ok 1 Group Id: [13] Rec: 198 Len: 34 ..... Ok 1 Group Id: [13] Rec: 199 Len: 34 ..... Ok 1 Group Id: [14] Rec: 0 Len: 37 ..... Ok 1 Group Id: [14] Rec: 1 Len: 37 ..... Ok 1 Group Id: [14] Rec: 2 Len: 37 ..... Ok 1 Group Id: [14] Rec: 3 Len: 37 ..... Ok 1 Group Id: [14] Rec: 4 Len: 37 ..... Ok 1 Group Id: [14] Rec: 5 Len: 37 ..... Ok 1 Group Id: [14] Rec: 6 Len: 37 ..... Ok 1 Group Id: [14] Rec: 7 Len: 37 ..... Ok 1 Group Id: [14] Rec: 8 Len: 37 ..... Ok 1 Group Id: [14] Rec: 9 Len: 37 ..... Ok 1 Group Id: [14] Rec: 10 Len: 37 ..... Ok 1 Group Id: [14] Rec: 11 Len: 37 ..... Ok 1 Group Id: [14] Rec: 12 Len: 37 ..... Ok 1 Group Id: [14] Rec: 13 Len: 37 ..... Ok 1 Group Id: [14] Rec: 14 Len: 37 ..... Ok 1 Group Id: [14] Rec: 15 Len: 37 ..... Ok 1 Group Id: [14] Rec: 16 Len: 37 ..... Ok 1 Group Id: [14] Rec: 17 Len: 37 ..... Ok 1 Group Id: [14] Rec: 18 Len: 37 ..... Ok 1 Group Id: [14] Rec: 19 Len: 37 ..... Ok 1 Group Id: [15] Rec: 0 Len: 37 ..... Ok 1 Group Id: [15] Rec: 1 Len: 37 ..... Ok 1 Group Id: [15] Rec: 2 Len: 37 ..... Ok 1 Group Id: [15] Rec: 3 Len: 37 ..... Ok 1 Group Id: [15] Rec: 4 Len: 37 ..... Ok 1 Group Id: [15] Rec: 5 Len: 37 ..... Ok 1 Group Id: [15] Rec: 6 Len: 37 ..... Ok 1 Group Id: [15] Rec: 7 Len: 37 ..... Ok 1 Group Id: [15] Rec: 8 Len: 37 ..... Ok 1 Group Id: [15] Rec: 9 Len: 37 ..... Ok 1 Group Id: [16] Rec: 0 Len: 37 ..... Ok 1 Group Id: [16] Rec: 1 Len: 37 ..... Ok 1 Group Id: [16] Rec: 2 Len: 37 ..... Ok 1 Group Id: [16] Rec: 3 Len: 37 ..... Ok 1 Group Id: [16] Rec: 4 Len: 37 ..... Ok 1 Group Id: [16] Rec: 5 Len: 37 ..... Ok 1 Group Id: [16] Rec: 6 Len: 37 ..... Ok 1 Group Id: [16] Rec: 7 Len: 37 ..... Ok 1 Group Id: [16] Rec: 8 Len: 37 ..... Ok 1 Group Id: [16] Rec: 9 Len: 37 ..... Ok 1 Group Id: [17] Rec: 0 Len: 40 ..... Ok 1 Group Id: [17] Rec: 1 Len: 40 ..... Ok 1 Group Id: [17] Rec: 2 Len: 40 ..... Ok 1 Group Id: [18] Rec: 0 Len: 2056 ... Ok 18 Group Id: [19] Rec: 0 Len: 15 ..... Ok 1 Group Id: [22] Rec: 0 Len: 162 .... Ok 2 Group Id: [23] Rec: 0 Len: 38 ..... Ok 1 Group Id: [23] Rec: 1 Len: 21 ..... Ok 1 Group Id: [23] Rec: 2 Len: 1004 ... Ok 9 Group Id: [26] Rec: 0 Len: 302 .... Ok 3 Group Id: [26] Rec: 1 Len: 302 .... Ok 3 Group Id: [26] Rec: 2 Len: 302 .... Ok 3 Group Id: [26] Rec: 3 Len: 302 .... Ok 3 Group Id: [26] Rec: 4 Len: 302 .... Ok 3 Group Id: [26] Rec: 5 Len: 302 .... Ok 3 Group Id: [26] Rec: 6 Len: 302 .... Ok 3 Group Id: [26] Rec: 7 Len: 302 .... Ok 3 Group Id: [26] Rec: 8 Len: 302 .... Ok 3 Group Id: [26] Rec: 9 Len: 302 .... Ok 3 Group Id: [26] Rec: 10 Len: 302 .... Ok 3 Group Id: [26] Rec: 11 Len: 302 .... Ok 3 Group Id: [26] Rec: 12 Len: 302 .... Ok 3 Group Id: [26] Rec: 13 Len: 302 .... Ok 3 Group Id: [26] Rec: 14 Len: 302 .... Ok 3 Group Id: [26] Rec: 15 Len: 302 .... Ok 3 Group Id: [26] Rec: 16 Len: 302 .... Ok 3 Group Id: [26] Rec: 17 Len: 302 .... Ok 3 Group Id: [26] Rec: 18 Len: 302 .... Ok 3 Group Id: [26] Rec: 19 Len: 302 .... Ok 3 Group Id: [26] Rec: 20 Len: 302 .... Ok 3 Group Id: [26] Rec: 21 Len: 302 .... Ok 3 Group Id: [26] Rec: 22 Len: 302 .... Ok 3 Group Id: [26] Rec: 23 Len: 302 .... Ok 3 Group Id: [26] Rec: 24 Len: 302 .... Ok 3 Group Id: [26] Rec: 25 Len: 302 .... Ok 3 Group Id: [26] Rec: 26 Len: 302 .... Ok 3 Group Id: [26] Rec: 27 Len: 302 .... Ok 3 Group Id: [26] Rec: 28 Len: 302 .... Ok 3 Group Id: [26] Rec: 29 Len: 302 .... Ok 3 Group Id: [27] Rec: 0 Len: 142 .... Ok 2 Group Id: [27] Rec: 1 Len: 142 .... Ok 2 Group Id: [27] Rec: 2 Len: 142 .... Ok 2 Group Id: [27] Rec: 3 Len: 142 .... Ok 2 Group Id: [27] Rec: 4 Len: 142 .... Ok 2 Group Id: [27] Rec: 5 Len: 142 .... Ok 2 Group Id: [27] Rec: 6 Len: 142 .... Ok 2 Group Id: [27] Rec: 7 Len: 142 .... Ok 2 Group Id: [28] Rec: 0 Len: 16 ..... Ok 1 Group Id: [28] Rec: 1 Len: 16 ..... Ok 1 Group Id: [28] Rec: 2 Len: 16 ..... Ok 1 Group Id: [28] Rec: 3 Len: 16 ..... Ok 1 Group Id: [28] Rec: 4 Len: 16 ..... Ok 1 Group Id: [28] Rec: 5 Len: 16 ..... Ok 1 Group Id: [28] Rec: 6 Len: 16 ..... Ok 1 Group Id: [28] Rec: 7 Len: 16 ..... Ok 1 Group Id: [29] Rec: 0 Len: 304 .... Ok 3 Group Id: [29] Rec: 1 Len: 304 .... Ok 3 Group Id: [29] Rec: 2 Len: 304 .... Ok 3 Group Id: [29] Rec: 3 Len: 304 .... Ok 3 Group Id: [29] Rec: 4 Len: 304 .... Ok 3 Group Id: [30] Rec: 0 Len: 136 .... Ok 2 Group Id: [32] Rec: 0 Len: 10 ..... Ok 1 Group Id: [32] Rec: 1 Len: 1 ...... Ok 1 Group Id: [32] Rec: 2 Len: 2 ...... Ok 1 Group Id: [33] Rec: 6 Len: 3 ...... Ok 1 Group Id: [33] Rec: 7 Len: 3 ...... Ok 1 Group Id: [33] Rec: 8 Len: 3 ...... Ok 1 Group Id: [33] Rec: 9 Len: 3 ...... Ok 1 Group Id: [33] Rec: 10 Len: 3 ...... Ok 1 Group Id: [33] Rec: 11 Len: 3 ...... Ok 1 Group Id: [33] Rec: 12 Len: 3 ...... Ok 1 Group Id: [33] Rec: 13 Len: 3 ...... Ok 1 Group Id: [34] Rec: 0 Len: 8 ...... Ok 1 Group Id: [34] Rec: 1 Len: 8 ...... Ok 1 Group Id: [34] Rec: 2 Len: 8 ...... Ok 1 Group Id: [34] Rec: 3 Len: 8 ...... Ok 1 Group Id: [34] Rec: 4 Len: 8 ...... Ok 1 Group Id: [34] Rec: 5 Len: 8 ...... Ok 1 Group Id: [34] Rec: 6 Len: 1 ...... Ok 1 Group Id: [34] Rec: 7 Len: 1 ...... Ok 1 Group Id: [35] Rec: 0 Len: 1 ...... Ok 1 Group Id: [36] Rec: 0 Len: 32 ..... Ok 1 Group Id: [36] Rec: 1 Len: 32 ..... Ok 1 Group Id: [36] Rec: 2 Len: 1 ...... Ok 1 Group Id: [36] Rec: 3 Len: 1 ...... Ok 1 Group Id: [36] Rec: 4 Len: 1 ...... Ok 1 Group Id: [36] Rec: 5 Len: 4 ...... Ok 1 Group Id: [36] Rec: 6 Len: 4 ...... Ok 1 Group Id: [36] Rec: 7 Len: 2 ...... Ok 1 Group Id: [36] Rec: 8 Len: 120 .... Ok 2 Group Id: [36] Rec: 9 Len: 1 ...... Ok 1 Group Id: [36] Rec: 10 Len: 2 ...... Ok 1 Group Id: [36] Rec: 11 Len: 6 ...... Ok 1 Group Id: [36] Rec: 12 Len: 17 ..... Ok 1 Group Id: [36] Rec: 13 Len: 3 ...... Ok 1 Group Id: [36] Rec: 14 Len: 450 .... Ok 4 Group Id: [36] Rec: 15 Len: 38 ..... Ok 1 Group Id: [36] Rec: 16 Len: 38 ..... Ok 1 Group Id: [36] Rec: 18 Len: 10 ..... Ok 1 Group Id: [37] Rec: 0 Len: 1 ...... Ok 1 Group Id: [37] Rec: 1 Len: 30 ..... Ok 1 Group Id: [37] Rec: 2 Len: 16 ..... Ok 1 Group Id: [38] Rec: 0 Len: 13 ..... Ok 1 Group Id: [38] Rec: 1 Len: 13 ..... Ok 1 Group Id: [38] Rec: 2 Len: 13 ..... Ok 1 Group Id: [38] Rec: 3 Len: 13 ..... Ok 1 Group Id: [38] Rec: 4 Len: 13 ..... Ok 1 Group Id: [38] Rec: 5 Len: 13 ..... Ok 1 Group Id: [38] Rec: 6 Len: 40 ..... Ok 1 Group Id: [38] Rec: 7 Len: 40 ..... Ok 1 Group Id: [38] Rec: 8 Len: 40 ..... Ok 1 Group Id: [38] Rec: 9 Len: 40 ..... Ok 1 Group Id: [38] Rec: 10 Len: 40 ..... Ok 1 Group Id: [40] Rec: 0 Len: 4 ...... Ok 1 Group Id: [40] Rec: 1 Len: 4 ...... Ok 1 Group Id: [40] Rec: 2 Len: 4 ...... Ok 1 Group Id: [40] Rec: 3 Len: 4 ...... Ok 1 Group Id: [40] Rec: 4 Len: 4 ...... Ok 1 Group Id: [40] Rec: 5 Len: 4 ...... Ok 1 Group Id: [40] Rec: 6 Len: 4 ...... Ok 1 Group Id: [40] Rec: 7 Len: 4 ...... Ok 1 Group Id: [41] Rec: 0 Len: 10 ..... Ok 1 Group Id: [41] Rec: 1 Len: 16 ..... Ok 1 Group Id: [41] Rec: 2 Len: 16 ..... Ok 1 Group Id: [41] Rec: 11 Len: 36 ..... Ok 1 Group Id: [41] Rec: 12 Len: 36 ..... Ok 1 Group Id: [42] Rec: 0 Len: 22 ..... Ok 1 Group Id: [42] Rec: 1 Len: 22 ..... Ok 1 Group Id: [42] Rec: 2 Len: 22 ..... Ok 1 Group Id: [42] Rec: 3 Len: 22 ..... Ok 1 Group Id: [42] Rec: 4 Len: 22 ..... Ok 1 Group Id: [42] Rec: 5 Len: 22 ..... Ok 1 Group Id: [43] Rec: 0 Len: 40 ..... Ok 1 Group Id: [43] Rec: 1 Len: 40 ..... Ok 1 Group Id: [43] Rec: 2 Len: 40 ..... Ok 1 Group Id: [43] Rec: 3 Len: 40 ..... Ok 1 Group Id: [43] Rec: 4 Len: 40 ..... Ok 1 Group Id: [43] Rec: 5 Len: 40 ..... Ok 1 Group Id: [46] Rec: 0 Len: 1 ...... Ok 1 Group Id: [54] Rec: 0 Len: 4 ...... Ok 1 Group Id: [57] Rec: 0 Len: 34 ..... Ok 1 Group Id: [60] Rec: 0 Len: 7 ...... Ok 1 Group Id: [61] Rec: 0 Len: 4 ...... Ok 1 Group Id: [68] Rec: 0 Len: 20 ..... Ok 1 Group Id: [68] Rec: 1 Len: 20 ..... Ok 1 Group Id: [68] Rec: 2 Len: 20 ..... Ok 1 Group Id: [68] Rec: 3 Len: 20 ..... Ok 1 Group Id: [68] Rec: 4 Len: 20 ..... Ok 1 Group Id: [68] Rec: 5 Len: 20 ..... Ok 1 Group Id: [68] Rec: 6 Len: 20 ..... Ok 1 Group Id: [68] Rec: 7 Len: 20 ..... Ok 1 Group Id: [68] Rec: 8 Len: 20 ..... Ok 1 Group Id: [68] Rec: 9 Len: 20 ..... Ok 1 Group Id: [68] Rec: 10 Len: 20 ..... Ok 1 Group Id: [68] Rec: 11 Len: 20 ..... Ok 1 Group Id: [68] Rec: 12 Len: 20 ..... Ok 1 Group Id: [68] Rec: 13 Len: 20 ..... Ok 1 Group Id: [68] Rec: 14 Len: 20 ..... Ok 1 Group Id: [68] Rec: 15 Len: 20 ..... Ok 1 Group Id: [68] Rec: 16 Len: 20 ..... Ok 1 Group Id: [68] Rec: 17 Len: 20 ..... Ok 1 Group Id: [68] Rec: 18 Len: 20 ..... Ok 1 Group Id: [68] Rec: 19 Len: 20 ..... Ok 1 Group Id: [74] Rec: 0 Len: 3 ...... Ok 1 Group Id: [76] Rec: 0 Len: 44 ..... Ok 1 Group Id: [83] Rec: 0 Len: 5 ...... Ok 1 Group Id:[109] Rec: 0 Len: 8 ...... Ok 1 Group Id:[128] Rec: 0 Len: 78 ..... Ok 1 Group Id:[133] Rec: 0 Len: 4 ...... Ok 1 Group Id:[133] Rec: 1 Len: 32 ..... Ok 1 Group Id:[133] Rec: 2 Len: 4 ...... Ok 1 Group Id:[137] Rec: 0 Len: 4 ...... Ok 1 Group Id:[137] Rec: 1 Len: 32 ..... Ok 1 Group Id:[137] Rec: 2 Len: 4 ...... Ok 1 Group Id:[145] Rec: 0 Len: 4 ...... Ok 1 Group Id:[145] Rec: 1 Len: 32 ..... Ok 1 Group Id:[145] Rec: 2 Len: 4 ...... Ok 1 Group Id:[149] Rec: 0 Len: 4 ...... Ok 1 Group Id:[149] Rec: 1 Len: 32 ..... Ok 1 Group Id:[149] Rec: 2 Len: 4 ...... Ok 1 Group Id:[152] Rec: 0 Len: 4 ...... Ok 1 Group Id:[152] Rec: 1 Len: 32 ..... Ok 1 Group Id:[152] Rec: 2 Len: 4 ...... Ok 1 Group Id:[157] Rec: 0 Len: 4 ...... Ok 1 Group Id:[157] Rec: 1 Len: 32 ..... Ok 1 Group Id:[157] Rec: 2 Len: 4 ...... Ok 1 Group Id:[161] Rec: 0 Len: 4 ...... Ok 1 Group Id:[161] Rec: 1 Len: 32 ..... Ok 1 Group Id:[161] Rec: 2 Len: 4 ...... Ok 1 Group Id:[164] Rec: 0 Len: 4 ...... Ok 1 Group Id:[164] Rec: 1 Len: 32 ..... Ok 1 Group Id:[164] Rec: 2 Len: 4 ...... Ok 1 Group Id:[169] Rec: 0 Len: 4 ...... Ok 1 Group Id:[169] Rec: 1 Len: 32 ..... Ok 1 Group Id:[169] Rec: 2 Len: 4 ...... Ok 1 Group Id:[173] Rec: 0 Len: 4 ...... Ok 1 Group Id:[173] Rec: 1 Len: 32 ..... Ok 1 Group Id:[173] Rec: 2 Len: 4 ...... Ok 1 Group Id:[181] Rec: 0 Len: 4 ...... Ok 1 Group Id:[181] Rec: 1 Len: 32 ..... Ok 1 Group Id:[181] Rec: 2 Len: 4 ...... Ok 1 Group Id:[185] Rec: 0 Len: 4 ...... Ok 1 Group Id:[185] Rec: 1 Len: 32 ..... Ok 1 Group Id:[185] Rec: 2 Len: 4 ...... Ok 1 Group Id:[193] Rec: 0 Len: 4 ...... Ok 1 Group Id:[193] Rec: 1 Len: 32 ..... Ok 1 Group Id:[193] Rec: 2 Len: 4 ...... Ok 1 Group Id:[197] Rec: 0 Len: 4 ...... Ok 1 Group Id:[197] Rec: 1 Len: 32 ..... Ok 1 Group Id:[197] Rec: 2 Len: 4 ...... Ok 1 Group Id:[205] Rec: 0 Len: 4 ...... Ok 1 Group Id:[205] Rec: 1 Len: 32 ..... Ok 1 Group Id:[205] Rec: 2 Len: 4 ...... Ok 1 Group Id:[209] Rec: 0 Len: 4 ...... Ok 1 Group Id:[209] Rec: 1 Len: 32 ..... Ok 1 Group Id:[209] Rec: 2 Len: 4 ...... Ok 1 Group Id:[217] Rec: 0 Len: 4 ...... Ok 1 Group Id:[217] Rec: 1 Len: 32 ..... Ok 1 Group Id:[217] Rec: 2 Len: 4 ...... Ok 1 Group Id:[218] Rec: 0 Len: 5 ...... Ok 1 Group Id:[221] Rec: 0 Len: 4 ...... Ok 1 Group Id:[221] Rec: 1 Len: 32 ..... Ok 1 Group Id:[221] Rec: 2 Len: 4 ...... Ok 1 Group Id:[222] Rec: 0 Len: 8 ...... Ok 1 Group Id:[222] Rec: 1 Len: 8 ...... Ok 1 Group Id:[222] Rec: 2 Len: 8 ...... Ok 1 Group Id:[222] Rec: 3 Len: 8 ...... Ok 1 Group Id:[222] Rec: 4 Len: 8 ...... Ok 1 Group Id:[222] Rec: 5 Len: 8 ...... Ok 1 Group Id:[222] Rec: 6 Len: 1 ...... Ok 1 Group Id:[222] Rec: 7 Len: 1 ...... Ok 1 Group Id:[224] Rec: 0 Len: 4 ...... Ok 1 Group Id:[224] Rec: 1 Len: 4 ...... Ok 1 Group Id:[224] Rec: 2 Len: 4 ...... Ok 1 Group Id:[224] Rec: 3 Len: 4 ...... Ok 1 Group Id:[224] Rec: 4 Len: 1 ...... Ok 1 Group Id:[224] Rec: 5 Len: 6 ...... Ok 1 Group Id:[224] Rec: 6 Len: 4 ...... Ok 1 Group Id:[224] Rec: 7 Len: 2 ...... Ok 1 Group Id:[224] Rec: 8 Len: 1 ...... Ok 1 Group Id:[224] Rec: 9 Len: 4 ...... Ok 1 Group Id:[224] Rec: 10 Len: 31 ..... Ok 1 Group Id:[224] Rec: 11 Len: 2 ...... Ok 1 Group Id:[224] Rec: 12 Len: 1 ...... Ok 1 Group Id:[224] Rec: 13 Len: 1 ...... Ok 1 Group Id:[224] Rec: 14 Len: 1 ...... Ok 1 Group Id:[224] Rec: 15 Len: 1 ...... Ok 1 Group Id:[224] Rec: 16 Len: 8 ...... Ok 1 Group Id:[224] Rec: 17 Len: 1 ...... Ok 1 Group Id:[224] Rec: 18 Len: 1 ...... Ok 1 Group Id:[224] Rec: 19 Len: 4 ...... Ok 1 Group Id:[224] Rec: 20 Len: 2 ...... Ok 1 Group Id:[224] Rec: 21 Len: 2 ...... Ok 1 Group Id:[224] Rec: 22 Len: 1 ...... Ok 1 Group Id:[224] Rec: 23 Len: 8 ...... Ok 1 Group Id:[224] Rec: 24 Len: 1 ...... Ok 1 Group Id:[224] Rec: 25 Len: 2 ...... Ok 1 Group Id:[224] Rec: 26 Len: 2 ...... Ok 1 Group Id:[224] Rec: 27 Len: 2 ...... Ok 1 Group Id:[224] Rec: 28 Len: 2 ...... Ok 1 Group Id:[224] Rec: 29 Len: 2 ...... Ok 1 Group Id:[224] Rec: 30 Len: 4 ...... Ok 1 Group Id:[224] Rec: 31 Len: 4 ...... Ok 1 Group Id:[224] Rec: 32 Len: 4 ...... Ok 1 Group Id:[224] Rec: 33 Len: 4 ...... Ok 1 Group Id:[224] Rec: 34 Len: 4 ...... Ok 1 Group Id:[224] Rec: 35 Len: 4 ...... Ok 1 Group Id:[224] Rec: 36 Len: 16 ..... Ok 1 Group Id:[224] Rec: 37 Len: 4 ...... Ok 1 Group Id:[224] Rec: 38 Len: 2 ...... Ok 1 Group Id:[224] Rec: 39 Len: 4 ...... Ok 1 Group Id:[224] Rec: 40 Len: 2 ...... Ok 1 Group Id:[224] Rec: 41 Len: 2 ...... Ok 1 Group Id:[224] Rec: 42 Len: 1 ...... Ok 1 Group Id:[224] Rec: 43 Len: 1 ...... Ok 1 Group Id:[224] Rec: 44 Len: 4 ...... Ok 1 Group Id:[224] Rec: 45 Len: 4 ...... Ok 1 Group Id:[224] Rec: 46 Len: 4 ...... Ok 1 Group Id:[224] Rec: 47 Len: 4 ...... Ok 1 Group Id:[224] Rec: 48 Len: 4 ...... Ok 1 Group Id:[224] Rec: 49 Len: 4 ...... Ok 1 Group Id:[224] Rec: 50 Len: 4 ...... Ok 1 Group Id:[224] Rec: 51 Len: 4 ...... Ok 1 Group Id:[224] Rec: 52 Len: 4 ...... Ok 1 Group Id:[224] Rec: 53 Len: 4 ...... Ok 1 Group Id:[224] Rec: 54 Len: 4 ...... Ok 1 Group Id:[224] Rec: 55 Len: 4 ...... Ok 1 Group Id:[224] Rec: 56 Len: 4 ...... Ok 1 Group Id:[224] Rec: 57 Len: 4 ...... Ok 1 Group Id:[224] Rec: 58 Len: 4 ...... Ok 1 Group Id:[224] Rec: 59 Len: 4 ...... Ok 1 Group Id:[224] Rec: 60 Len: 4 ...... Ok 1 Group Id:[224] Rec: 61 Len: 4 ...... Ok 1 Group Id:[224] Rec: 62 Len: 4 ...... Ok 1 Group Id:[224] Rec: 63 Len: 4 ...... Ok 1 Group Id:[224] Rec: 64 Len: 4 ...... Ok 1 Group Id:[224] Rec: 65 Len: 4 ...... Ok 1 Group Id:[224] Rec: 66 Len: 4 ...... Ok 1 Group Id:[224] Rec: 67 Len: 4 ...... Ok 1 Group Id:[224] Rec: 68 Len: 4 ...... Ok 1 Group Id:[224] Rec: 69 Len: 4 ...... Ok 1 Group Id:[224] Rec: 70 Len: 4 ...... Ok 1 Group Id:[224] Rec: 71 Len: 4 ...... Ok 1 Group Id:[224] Rec: 72 Len: 4 ...... Ok 1 Group Id:[224] Rec: 73 Len: 4 ...... Ok 1 Group Id:[224] Rec: 74 Len: 4 ...... Ok 1 Group Id:[224] Rec: 75 Len: 4 ...... Ok 1 Group Id:[224] Rec: 76 Len: 4 ...... Ok 1 Group Id:[224] Rec: 77 Len: 4 ...... Ok 1 Group Id:[224] Rec: 78 Len: 4 ...... Ok 1 Group Id:[224] Rec: 79 Len: 4 ...... Ok 1 Group Id:[224] Rec: 80 Len: 4 ...... Ok 1 Group Id:[224] Rec: 81 Len: 4 ...... Ok 1 Group Id:[224] Rec: 82 Len: 2 ...... Ok 1 Group Id:[224] Rec: 83 Len: 4 ...... Ok 1 Group Id:[224] Rec: 84 Len: 2 ...... Ok 1 Group Id:[224] Rec: 85 Len: 1 ...... Ok 1 Group Id:[224] Rec: 86 Len: 16 ..... Ok 1 Group Id:[224] Rec: 87 Len: 88 ..... Ok 1 Group Id:[224] Rec: 88 Len: 2 ...... Ok 1 Group Id:[224] Rec: 89 Len: 4 ...... Ok 1 Group Id:[224] Rec: 90 Len: 2 ...... Ok 1 Group Id:[224] Rec: 91 Len: 2 ...... Ok 1 Group Id:[224] Rec: 92 Len: 2 ...... Ok 1 Group Id:[224] Rec: 93 Len: 2 ...... Ok 1 Group Id:[224] Rec: 94 Len: 2 ...... Ok 1 Group Id:[224] Rec: 95 Len: 2 ...... Ok 1 Group Id:[224] Rec: 96 Len: 2 ...... Ok 1 Group Id:[224] Rec: 97 Len: 2 ...... Ok 1 Group Id:[224] Rec: 98 Len: 2 ...... Ok 1 Group Id:[224] Rec: 99 Len: 2 ...... Ok 1 Group Id:[224] Rec: 100 Len: 2 ...... Ok 1 Group Id:[224] Rec: 101 Len: 2 ...... Ok 1 Group Id:[224] Rec: 102 Len: 2 ...... Ok 1 Group Id:[224] Rec: 103 Len: 2 ...... Ok 1 Group Id:[224] Rec: 104 Len: 2 ...... Ok 1 Group Id:[224] Rec: 105 Len: 2 ...... Ok 1 Group Id:[224] Rec: 106 Len: 2 ...... Ok 1 Group Id:[224] Rec: 107 Len: 2 ...... Ok 1 Group Id:[224] Rec: 108 Len: 2 ...... Ok 1 Group Id:[224] Rec: 109 Len: 2 ...... Ok 1 Group Id:[224] Rec: 110 Len: 2 ...... Ok 1 Group Id:[224] Rec: 111 Len: 2 ...... Ok 1 Group Id:[224] Rec: 112 Len: 2 ...... Ok 1 Group Id:[224] Rec: 113 Len: 2 ...... Ok 1 Group Id:[224] Rec: 114 Len: 2 ...... Ok 1 Group Id:[229] Rec: 0 Len: 4 ...... Ok 1 Group Id:[229] Rec: 1 Len: 32 ..... Ok 1 Group Id:[229] Rec: 2 Len: 4 ...... Ok 1 Group Id:[230] Rec: 0 Len: 5 ...... Ok 1 Group Id:[231] Rec: 0 Len: 7 ...... Ok 1 Group Id:[233] Rec: 0 Len: 4 ...... Ok 1 Group Id:[233] Rec: 1 Len: 32 ..... Ok 1 Group Id:[233] Rec: 2 Len: 4 ...... Ok 1 Group Id:[234] Rec: 0 Len: 8 ...... Ok 1 Group Id:[234] Rec: 1 Len: 8 ...... Ok 1 Group Id:[234] Rec: 2 Len: 8 ...... Ok 1 Group Id:[234] Rec: 3 Len: 8 ...... Ok 1 Group Id:[234] Rec: 4 Len: 8 ...... Ok 1 Group Id:[234] Rec: 5 Len: 8 ...... Ok 1 Group Id:[234] Rec: 6 Len: 1 ...... Ok 1 Group Id:[234] Rec: 7 Len: 1 ...... Ok 1 Group Id:[236] Rec: 0 Len: 4 ...... Ok 1 Group Id:[236] Rec: 1 Len: 32 ..... Ok 1 Group Id:[236] Rec: 2 Len: 4 ...... Ok 1 Group Id:[241] Rec: 0 Len: 4 ...... Ok 1 Group Id:[241] Rec: 1 Len: 32 ..... Ok 1 Group Id:[241] Rec: 2 Len: 4 ...... Ok 1 Group Id:[242] Rec: 0 Len: 5 ...... Ok 1 Group Id:[245] Rec: 0 Len: 4 ...... Ok 1 Group Id:[245] Rec: 1 Len: 32 ..... Ok 1 Group Id:[245] Rec: 2 Len: 4 ...... Ok 1 Group Id:[246] Rec: 0 Len: 8 ...... Ok 1 Group Id:[246] Rec: 1 Len: 8 ...... Ok 1 Group Id:[246] Rec: 2 Len: 8 ...... Ok 1 Group Id:[246] Rec: 3 Len: 8 ...... Ok 1 Group Id:[246] Rec: 4 Len: 8 ...... Ok 1 Group Id:[246] Rec: 5 Len: 8 ...... Ok 1 Group Id:[246] Rec: 6 Len: 1 ...... Ok 1 Group Id:[246] Rec: 7 Len: 1 ...... Ok 1 Group Id:[248] Rec: 0 Len: 4 ...... Ok 1 Group Id:[248] Rec: 1 Len: 32 ..... Ok 1 Group Id:[248] Rec: 2 Len: 4 ...... Ok 1 Group Id:[253] Rec: 0 Len: 4 ...... Ok 1 Group Id:[253] Rec: 1 Len: 32 ..... Ok 1 Group Id:[253] Rec: 2 Len: 4 ...... Ok 1 Group Id:[254] Rec: 0 Len: 5 ...... Ok 1 Write PM Done, Time: 00:29 |
