03-13-2010, 07:53 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: manila philipines
Member: 1173732 Status: Offline Sonork: 100.1605145 Thanks Meter: 68 | pls help logger on mx key ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 88DE [ST 58MR016C,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C154ED:2984DA60 ASIC type: 2 UEM Imei: 35620900050145 Connecting to server ...OK, Login ... Hello C080xxxxx, you have 2010 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35620900050145.RP L" ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 88DE [ST 58MR016C,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C154ED:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-18 SW Version: V 8.11 19-06-06 RH-18 (c) NMP 1100 Imei plain: ??????????????-? Product Code: 0510227 Cellular System: GSM ASIC ID: 0x1201, type: 2 Ppm Id: EJ Language Pack: - not available. Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: 382E31310A31392D PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! whats wrong sir????? thank you very much |
03-13-2010, 08:35 | #3 (permalink) |
Member: 1173732 Status: Offline Sonork: 100.1605145 Thanks Meter: 68 | sir do have a produce how to work this case??? i restore imei but the imei is 14digits 35620900050145 this the logs Easy Imei restore for DCT4 phones started. ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 88DE [ST 58MR016C,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C154ED:2984DA60 ASIC type: 2 UEM Imei: 35620900050145 Flash Imei: 35620900050145 Investigating flash imei ... Calculating Imei restore ... ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 88DE [ST 58MR016C,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C154ED:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Imei restore succesfull ! if you were restoring from imei patched phone, you should reflash the firmware to remove SW patch. Phone Type: RH-18 SW Version: V 8.11 19-06-06 RH-18 (c) NMP 1100 Imei plain: 35620900050145-9 Product Code: 0510227 Cellular System: GSM ASIC ID: 0x1201, type: 2 Ppm Id: EJ Language Pack: - not available. Imei net: 35620900050145 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000000000 BLOCK 1: 1.CORRUPTED what is the next step???? the sir |
how to unlock 2610b .07.04a on mx-key please help | ner21 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 12-30-2009 12:47 |
Possible to unlock 2610b v7.04a on MX-Key? | jesuraja | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 11-19-2009 07:09 |
why i cant find JAF or mt-box on mx-key intreface? | xiakaijun | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 09-19-2009 12:25 |
help how to use sx4???? on mx key | mawan161080 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 06-26-2009 18:47 |
[MXKEY - INFO] More Feature on MX-Key | Andra | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 22 | 04-29-2009 05:19 |
