plz help me mx key team help me wat this problem when did flash any phone Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\RPL\35320903453218_BA CK.rpl). Processing file: rh99_05.060 as MCU [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 Boot error: 55 04 00 92 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 8.062 s |
1000% cable problem use good quietly cables............ |
ya thats right change ur cable use the orignal box cable |
i have same problem but i changed 3 tested cables but not solved |
BR, Manole |
Friend this is your jaf box this damage, sorry |
HELP? WHEN I GOING TO FALASH ANY PHONE GIVE THIS ERROR ...I GOT THIS PROBLEM WHEN I Updater_V4 TNX Using device: POTATO BOX, FW ver: 01.B2 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\RPL\35320903453218_BA CK.rpl). Processing file: rh99_05.800 as MCU [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 Boot error: 55 04 00 92 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 8.032 s |
HELP MX KEY TEAM HOW CAN I SOLV THIS PROBLEM Using device: POTATO BOX, FW ver: 01.B2 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\RPL\35320903453218_BA CK.rpl). Processing file: rh99_05.800 as MCU [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 Boot error: 55 04 00 92 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 8.032 s |
Your box damaged by Potato Man Raskal I have made warning and advice long time ago: http://forum.gsmhosting.com/vbb/f550...update-957126/ http://forum.gsmhosting.com/vbb/f550...rmware-925332/ The box you have in your hand is a Potato interface what you calling it JAF it belong to Gsm Traders LTD. from Hong Kong, Raskal company wich have the trademark for the names JAF. http://i782.photobucket.com/albums/y...ftrademark.jpg Go to Potato Box forum and ask for support. J.A.F - Just Another Flasher - GSM-Forum Here is MXKEY support forum. Sorry friend, Topic closed acording to mxkey forum rules: http://forum.gsmhosting.com/vbb/f550...hreads-967354/ br, |
