Old 03-21-2011, 12:16   #1 (permalink)
uzmantel's Avatar
Member: 163458
Sonork: 100.1606694
Thanks Meter: 503
7230 rm-604 flash problem.. (ANSWERED)
Hi All team What is this problem..??
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011)
Processing MCU file: rm598__09.83.mcusw
[BB5,XSR 1.6] size: 28.82 MB
Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: A7AB61A
CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001030
CMT PUBLIC ID: 1F3002049E9B5440506F3D2192D676DA210F7126
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
CMT ROM ID: 67E82268F29CEA60
Loading CMT secondary boot code
SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3B40
Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
Old 03-21-2011, 12:42   #2 (permalink)
uzmantel's Avatar
Member: 163458
Sonork: 100.1606694
Thanks Meter: 503
Problem slove
NPC_DATA is empty.
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_3548*******_PM.rp l"
Battery voltage: 3835 mV
Phone type: RM-604
Product code: 0590626
SW version: V 09.83 21-09-10 RM-604 (c) Nokia
LanguagePkg version: V 09.83 21-09-10 RM-598 (c) Nokia MEA
Version from phone: 09.83
Version from file: 09.83
CMT PUBLIC ID: 1B5001191E735440C72A43659F314B04684F7653
Secondary boot loaded.
FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID2: 0098 0030 - 0000 0131 [Toshiba NAND-1G] type: MuxOneNAND,CMT
ALG [35]: XSR 1.6
Loading CMT update server data
Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0x8F9A0
Update server code loaded.
Verifying communication to device OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_3548**********_CE RT.rpl"
CMT PAPUBKEYS HASH: 4431C834027BBA0D18A5ED745CAFA04BA679A74A
Storing certificate [NPC, CCC, HWC, R&D] OK.
Partitioning....
Partitioning complete
Erase size: 37.69 MB
CMT MuxOneNAND area [00020000-000203FF]
CMT MuxOneNAND area [00060000-0009FFFF]
CMT MuxOneNAND area [000A0000-0025FFFF]
CMT MuxOneNAND area [003E0000-005DFFFF]
CMT MuxOneNAND area [005E0000-010DFFFF]
CMT MuxOneNAND area [01EC0000-01EDFFFF]
CMT MuxOneNAND area [027C0000-02CBFFFF]
CMT MuxOneNAND area [077C0000-07B3FFFF]
CMT MuxOneNAND area [010E0000-01EBFFFF]
Formating partition ...
Flash programming ...
CMT PAPUBKEYS: 4431C834027BBA0D18A5ED745CAFA04BA679A74A (RAP Certificate 192 v.1) written.
Programming completed in 59.875 s
Processing PPM file: rm598__09.83.ppm_c
[BB5,XSR 1.6] size: 6.21 MB
Erase size: 8.87 MB
CMT MuxOneNAND area [01EE0000-027BFFFF]
Programming completed in 13.110 s
Processing CNT file: rm598__09.83.image_c_0590088_007
[BB5,XSR 1.6] size: 14.99 MB
Erase size: 75.06 MB
CMT MuxOneNAND area [02CC0000-077BFFFF]
Programming completed in 31.328 s
Total time for flashing process(boot+erase+write) was 1 min 57.969 s
Waiting for device boot up ...
Device found: nmwcdc\Nokia 7230 USB Phonet, PORT_ID: 3A63ACF6
Phone Type: RM-604 (Nokia 7230)
SW Version: V 09.83 21-09-10 RM-604 (c) Nokia
Imei plain: 3548**********
Product Code: 0590626
Battery voltage: 3749 mV
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 3548**********
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 03-22-2011, 02:56   #3 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
please share with others.
how you solved your problem?
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.14591 seconds with 9 queries
