03-28-2010, 12:50 | #1 (permalink) |
Crazy Poster Join Date: Jan 2010 Location: gurdaspur india
Member: 1199512 Status: Offline Thanks Meter: 5 | plz hlp mx team Using device: J.A.F, FW ver: 01.B4 Library version: 1.0.0.7548(21-01-2010), 1.0.0.12651(18-03-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0016F74CA3BDA66 ASIC type: 11 UEM Imei: 35293802344759 Flash Imei: 35293802344759 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35293802344759_BA CK.rpl" Processing file: rm305_7.880 as MCU [DCT4,DCT4 ALGORITHM] size: 2.34 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0016F74C:2984DA60 Area [01000000-0100FFFF] erased in 0.578 s Area [01010000-0179FFFF] erased in 37.052 s Area [017A0000-017EFFFF] erased in 2.188 s Area [01F00000-01FDFFFF] erased in 5.110 s Flash programming ... Programming completed in 55.664 s File Processed in 1 min 57.891 s Processing file: rm305_image_7.88mp as CNT [DCT4,DCT4 ALGORITHM] size: 180.30 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0016F74C:2984DA60 Area [01760000-0179FFFF] erased in 1.406 s Flash programming ... Programming completed in 4.860 s Content extract fail, continue anyway ... File Processed in 2 min 16.360 s Processing file: rm305_7.88mp as PPM [DCT4,DCT4 ALGORITHM] size: 3.52 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0016F74C:2984DA60 Area [01240000-0125FFFF] erased in 0.625 s Area [01260000-0175FFFF] erased in 26.003 s Flash programming ... Programming completed in 1 min 23.337 s File Processed in 2 min 7.310 s Flashing completed in 7 min 21.007 s |
03-29-2010, 08:41 | #8 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: Adilabad
Member: 890104 Status: Offline Sonork: 100.1597567 Thanks Meter: 138 | 1650 Content extract fail, continue anyway .. solved Quote:
BR, Content extract fail, continue anyway ... This is a local mode problem of phone just change local mode ic [OR] THANKS ME IF LIKE IT HELP EACH OTHERS | |
03-29-2010, 08:57 | #9 (permalink) |
No Life Poster Join Date: May 2007 Location: .::Rawalpindi::.
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | manual rease these addresses one by one at ufs and flash again 01000000-01FFFFFF 01000000-0100FFFF 01010000-0179FFFF 017A0000-017EFFFF 01F00000-01FDFFFF 01760000-0179FFFF and post result..... tested many times...... |
03-31-2010, 09:33 | #11 (permalink) | |
Member: 890104 Status: Offline Sonork: 100.1597567 Thanks Meter: 138 | Quote:
In softwares of hwk the cnt file will use 128k file or it will convert thats why you cant get any error. have u made ui settings | |
11-01-2011, 10:14 | #12 (permalink) |
Freak Poster Join Date: May 2008 Location: kashmir
Member: 765926 Status: Offline Sonork: [email protected] Thanks Meter: 57 | well i am facing the same problem with dct4 handsets. it is definetely a bug. |
plz help mx team | denny86 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-15-2010 06:03 |
mx team hlp me plz | naveedbutt | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-02-2010 07:08 |
plz help MX TEAM | SinghForHelp | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-02-2010 22:45 |
plz help mx team | raza ahmad | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 10-21-2009 13:29 |
problem in pinfinder.. plz hlp me team | peter002 | Infinity-Box | 3 | 04-18-2009 15:57 |
