02-03-2010, 13:04 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: DUBAI, UAE
Member: 497374 Status: Offline Sonork: 1587252:AZAD Thanks Meter: 93 | Post here sd repair from mxkey thanks |
The Following User Says Thank You to azad4u For This Useful Post: |
02-03-2010, 15:23 | #2 (permalink) |
Member: 497374 Status: Offline Sonork: 1587252:AZAD Thanks Meter: 93 | n96 successfully sd repair by mxkey N96 SD Repair Done............ Phone Type: RM-247 (Nokia N96-1) SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia Imei plain: 35640602580570-5 Product Code: 0573063 ApeCoreSw: 30.033 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356406025805705 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF repair Phone Type: RM-247 (Nokia N96-1) SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia Imei plain: 35640602580570-5 Product Code: 0573063 ApeCoreSw: 30.033 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356406025805705 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-03-2010, 15:36 | #3 (permalink) |
Crazy Poster Join Date: Feb 2010
Member: 1226388 Status: Offline Sonork: jk khan Thanks Meter: 13 | N91 sd repaired succesfully Phone Type: RM-43 (Nokia N91-1) SW Version: V w33_06w24v4 13-09-06 RM-43 (c) Nokia. Imei plain: 3583XXXXXXXXXX Product Code: 0524312 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed "RM-43" folder created. Imei net: 3583XXXXXXXXXX Version: SIMLOCK SERVER VERSION 62 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF REPAIR Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 Product: V w33_06w24v4 13-09-06 RM-43 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 9.123 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-43_358391001211425_SD.RPL" Updating SUPERDONGLE_KEY ...OK AFTER REPAIR Phone Type: RM-43 (Nokia N91-1) SW Version: V w33_06w24v4 13-09-06 RM-43 (c) Nokia. Imei plain: 35835XXXXXXXXX Product Code: 0524312 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35839XXXXXXXX Version: SIMLOCK SERVER VERSION 62 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
6710n not working SD REPAIR in mxkey[ANSWERED] | fatih | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-08-2010 23:04 |
3110 not charging problem solved by sd repair thanks mxkey | SanjanMobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-16-2010 16:55 |
100% ok SD Repair with Mxkey | ashik123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-06-2010 10:20 |
3110c 100% ok SD Repair with Mxkey | alpona_su | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-06-2010 10:12 |
n96 successfully sd repair by mxkey | azad4u | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-03-2010 15:24 |
