03-14-2012, 21:23 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Power of mxkey 2nd thing is when flashing working dct4 phones if content extract failed appears on screen while writing cnt file, then after flashing process finish, phone does not go in local mode & phone goes off & dead with all boxes. See the power of mxkey while flashing old dct4 phone 2600 today, i also faced the error while flashing, but mxkey not making it dead & saved my phone. Thanks MXKEY team. See this: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085DA85 Using device: HTI, FW ver: 00.50, SN: 00011D3F Connection status: UHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20454(13-03-2012), Library ver: 1.0.0.13962(12-03-2012) Rpl backup already exist (C:\mobileEx\3.5\data\backup\35881500321152_BACK.r pl). Processing MCU file: rh59_06.410 [DCT4,DCT4 ALGORITHM] size: 1.70 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00DFE6CE:2984DA60 Area [01000000-0100FFFF] erased in 0.453 s Area [01010000-013AFFFF] erased in 25.016 s Area [013B0000-013EFFFF] erased in 1.718 s Area [017B0000-017EFFFF] erased in 0.047 s Area [01FB0000-01FEFFFF] erased in 0.016 s Flash programming ... Programming completed in 13.688 s File Processed in 49.094 s Processing CNT file: rh590_nai6.41mg_2 [DCT4,DCT4 ALGORITHM] size: 190.59 KB Supported Ids: 0120, 0121, 1120, 1021, 1201, 2201 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00DFE6CE:2984DA60 Area [01370000-013AFFFF] erased in 1.735 s Flash programming ... Programming completed in 1.656 s Content extract fail, continue anyway ... File Processed in 1 min 56.031 s Processing PPM file: rh59_06.41mg [DCT4,DCT4 ALGORITHM] size: 1.07 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00DFE6CE:2984DA60 Area [011B0000-011BFFFF] erased in 0.438 s Area [011C0000-0136FFFF] erased in 11.656 s Flash programming ... Programming completed in 8.813 s File Processed in 29.188 s Total time for flashing process(boot+erase+write) was 3 min 14.313 s Phone type: RH-59 SW version: V 6.41 09-01-06 RH-59 (c) NMP 2600 Imei plain: 35881500321152-0 Product code: 0527467 Cellular system: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MG Language Pack: English,Hindi,Marathi Master code: 4014013661 Imei net: 35881500321152 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN br, zuberchowdhry |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Please Help, Pinout of N8810 | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-30-2010 15:53 |
GID for nokia 5110 of telecel or TMN or Optimus? | hicom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-13-1999 15:29 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
