05-26-2009, 12:31 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: OrbitGsm.Com
Member: 650840 Status: Offline Thanks Meter: 622 | "pm auth for bb5 in mx-key not working" FROM FIRST TIME I WAS UNABLE TO DO PM AUTH FOR BB5 PHONES IT"S CRT DATA & RPL IS 100%OK.SO,WHERE"S THE PROBLEM????? BUS CHECK IS ALSO VERY SOLO IN MX-KEY PLZ,SUPPORTERS HELP ME ON THIS SITUATION!!!!! PLZ CHECK THIS PROBLEM BR, P@lash_c6 |
05-26-2009, 12:50 | #2 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Philippines
Member: 230087 Status: Offline Thanks Meter: 373 | Reset NPC Write PM then back-up rpl then use sx-4 If this fails, it means it has bad RPL DATA. Your pone might be "CHARGING NOT SUPPORTED" or "GOES OFF EVERY 2-5 MINUTES" |
05-26-2009, 13:01 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: india
Member: 681945 Status: Offline Thanks Meter: 422 | http://rapidshare.com/files/23739417...INK__.rar.html try with these videos, this may help u if u r using wrong mathod some clips for help using mx key |
05-26-2009, 13:06 | #4 (permalink) | |
Member: 650840 Status: Offline Thanks Meter: 622 | Quote:
this n70 is 100% ok phone this is working fine it is a new phone charging ok.... I tried many times by npc reset & write full backup same problem occur | |
05-26-2009, 13:43 | #5 (permalink) |
No Life Poster Join Date: May 2005 Location: ((EGYPT)) walid badr Age: 44
Member: 148424 Status: Offline Sonork: 100.93619 Thanks Meter: 112 | i think it's a server problem not phone coz i tryed more then 6 phone worked well but same error hope to slove this problem soon br |
05-26-2009, 13:56 | #7 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Quote:
server clearly says superdongle key corrupted, its mean phone rpl is not good, if u want to try sx4 then just buy rpl for this phone and write then use sx4, will work 100%... coz i tried in morning, server was working good.. | |
The Following User Says Thank You to himanshu taldar For This Useful Post: |
05-26-2009, 17:40 | #8 (permalink) | |
Member: 148424 Status: Offline Sonork: 100.93619 Thanks Meter: 112 | Quote:
but not work and sx4 worked good by jaf castumer care and write pm normaly br Last edited by mr.6630; 05-26-2009 at 17:47. | |
SD Auth in Mx-key Good news for mx-key user | muksforu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-28-2010 12:02 |
Sx4 auth problem in mx-key![solved] | palash_c6 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 33 | 01-22-2010 09:00 |
need unlock video or detail of bb5 in mx key urgent | shaikh_zubin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 10-01-2009 14:10 |
need unlock video or detail of bb5 in mx key urgent | shaikh_zubin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 10-01-2009 09:38 |
im new user in mx key not open soft my pc | ankur_rani143 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 04-28-2009 02:22 |
