02-19-2010, 17:19 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: HWKBOX,MX-KEY,CYCLONE SL3 ;-)
Member: 217461 Status: Offline Thanks Meter: 150 | For all users with UFS protest! As you know from version 3.2 Rev. 5.4 With UFS you have the bug in Flash and rx buffers are many months that we report this bug in hundreds of posts without correcting this bug favoring users with jaf box and then do as I change the signature until correct this bug in your location! BR. |
The Following 2 Users Say Thank You to gprsman For This Useful Post: |
02-19-2010, 17:28 | #2 (permalink) |
Freak Poster Join Date: May 2008 Location: INDIA
Member: 775587 Status: Offline Thanks Meter: 29 | use colne jaf box it is so cheap in price. if u having probleme with ufs, in my point of viwe that is not a big issue, abt flashing u can use many crack alternatives. whatever done mxkey team done thier best like sd repair. |
02-19-2010, 17:33 | #3 (permalink) | |
Member: 217461 Status: Offline Thanks Meter: 150 | Quote:
thanks bro not buy jaf principle because mx-key was born with ufs and must correct those bugs BR. | |
02-19-2010, 17:59 | #4 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | Quote:
Its just me who have DeJaVu or what? I read all your previous post, and all same subject ! why dont you just post only one with spesific log, so it will be clear enough for us to fix what you said as bugs. keep posting same subject in multiple thread is same as SPAM. BR. ALIM | |
02-19-2010, 19:13 | #5 (permalink) | |
this is not spam but the reality is many months that you have this bug with ufs and corrects him why? can not plan how version 3.2 rev 5.4 seems simple to you that is a great programmer BR. gprsman. | |
02-20-2010, 08:33 | #7 (permalink) | |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Quote:
If you are not able to do so, i will be forced to delete all your spam posts and to ban you from this forum since your posts are just spreading wrong information w/o any logs as proof to help us solve this bugs. BR, Manole | |
The Following 5 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2010, 08:46 | #8 (permalink) | |
Insane Poster Join Date: May 2007 Location: India
Member: 519307 Status: Offline Sonork: 100.1584418 Thanks Meter: 26 | Quote:
to all dear mambers and supporter of Manole the Manole is great cheater in mobile history they closed the p-key updating site bb5king and earn money and now what they wish close the mx key support site many p-key of jaf by Manole is blocked I knew it is about 7065890250 pec of all members think how much they earn money be ware ................. | |
02-20-2010, 09:05 | #9 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Philippines
Member: 257511 Status: Offline Thanks Meter: 69 | hi! here are some logs: bus check: Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 88BE [ST 58NR064E-F,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00814D95:2984DA60 ASIC type: 2 UEM Imei: 07201243046 Flash Imei: 07201243046 MasterCode: 3250432641 RPL saved to "C:\mobileEx\3.3\data\backup\07201243046_1266656410_BACK.rpl" Phone Type: NHL-4 (Nokia 7210) SW Version: V 5.63 11-Jun-04 NHL-4 (c) Nokia. Imei plain: - Imei OTP: 07201243046 Product Code: 0506686 Cellular System: GSM ASIC ID: 0x1120, type: 2 Ppm Id: A Language Pack: English,Finnish,Swedish,Danish,Norwegian,German,Icelandic Imei net: 4217F6A000000F Version: SIMLOCKLIB VERSION 2.26 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Code: Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\_BACK.rpl). Processing file: nhl4__05.630 as MCU [DCT4,DCT4 ALGORITHM] size: 5.10 MB Supported Ids: 0120, 1120 ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 88BE [ST 58NR064E-F,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00814D95:2F23DA60 Area [01000000-0100FFFF] erased in 1.062 s Area [01010000-0157FFFF] erased in 1 min 30.140 s Area [016B0000-017EFFFF] erased in 21.203 s Area [01EB0000-01FEFFFF] erased in 0.593 s Flash programming ... Programming completed in 58.328 s File Processed in 3 min 0.938 s Processing file: nhl4__05.63.ucp_va as CNT [DCT4,DCT4 ALGORITHM] size: 323.83 KB Supported Ids: 0120, 1120 ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! flashing terminated ! Flashing terminated with error(s) in 3 min 47.734 s RX Buffer: D372 |
02-20-2010, 09:07 | #10 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: P A K I S T A N Age: 42
Member: 237155 Status: Offline Thanks Meter: 415 | Quote:
http://forum.gsmhosting.com/vbb/showthread.php?t=927984 many other users are reporting same problem.do you think all are mad and only waste their time to spam the board ? | |
02-22-2010, 05:50 | #13 (permalink) | |
Hi MANOLE, as you can see from posts and log this bug with ufs existed for many months I have version 3.2 rev 5.4 Alim suggested that programs like this version but leaving only update without first correcting the main ones. I do not spam'm on your side and Alim But all this time is absurd without correcting bug with ufs. BR. | |
02-22-2010, 05:53 | #14 (permalink) | |
02-22-2010, 06:40 | #15 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 594881 Status: Offline Thanks Meter: 77 | you can still flash trhu ufs...... tried this and it worked.... flash mcu ppm and cnt separately.... its time consuming but if you only have ufs then you have no choice but to flash yhat way.... |
See this, is it better for all users ?? especially new users | hasnain | FuriousGold | 2 | 05-23-2009 00:18 |
how about free 5 logs for all users of sagdd with or without loaded logs before. | MR.PRESIDENT | SAGEM JTAG UNLOCKER | 9 | 02-01-2009 10:39 |
For all users , who have a problem with last HWK suite | ribbentrop | Twisterflasher | 2 | 08-26-2007 15:38 |
!!! For all users, resellers and product supporters of UFS Tornado box !!! | MANOLE | UFS2 + UFS3-Tornadoflasher | 0 | 06-26-2007 08:44 |
for all users of (GTI-UFS-MT-BOX-PBB-JAF) | GSM SHADOW | Nokia Base Band 5 ( BB-5 ) | 44 | 12-25-2005 17:46 |
