problem flashing 2680s need help...problem flashing 2680 here is the log Code: Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) |
also when flashing 6070 it shows same error....is this a bug?? |
check flash cable connection, mine after the flash can even unlock via server Imei net: 356390028***** Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555035555 SIMLOCK_DATA corrupted! Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 [CR1]DCT4PLUS remaining credit: 46 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-392_356390028*****_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 356390028***** Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
i use universal cable |
i need pin out...can u share please |
how many pins did u use??????????// |
i used 5 pin, . . . . (. .) . (. . .) con batt l l l sory for the pic :) |
bro use mxkey ufc cable set i hope ur problem will be solved |
Same to me .Please write the complete guide for flash 2680s by MXKEY or JAF. Need quick response . Thanks advanced |
use 5.1k, if still not success - force using 7.5k |
