11-05-2009, 19:45 | #1 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 864271 Status: Offline Thanks Meter: 31 | Problem Unlock Nokia 5800 Phone Type: RM-356 (Nokia 5800 XpressMusic) SW Version: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia Imei plain: 35421603861860-3 Product Code: 0581300 ApeCoreSw: V 21.0.025 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354216038618603 Version: SIMLOCK SERVER Provider: Orange, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23433F, DATA=23433F BLOCK 2: 1=LOCKED (MCC+MNC): 23486F, DATA=23486F |
11-05-2009, 20:50 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | ouchhh .. example in my 6300 headset, that it PA_SL. if some one confuse about SL1,SL2 or maybe next nokia security update we try add that info br, |
11-06-2009, 15:08 | #8 (permalink) |
Member: 864271 Status: Offline Thanks Meter: 31 | Friend of mobile-mx with this new update is failing to do anything flash or nothing when I click itentify of the same error in all someone would have the solution to these errors since ja appreciate the help |
11-07-2009, 22:03 | #10 (permalink) |
Freak Poster Join Date: Oct 2005 Location: ITALY
Member: 192348 Status: Offline Thanks Meter: 6 | For me there are problems again! When i try to update SpLock, with USF\HWK the log is: Imei: 3542160******** Version: SIMLOCK SERVER Provider: Retevision Movil Amena, Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 21403F, DATA=21403F Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot(0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x190C bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending Certificate(0x1A20 bytes) ...OK Calculating NCK using security server ... Connecting to server[nkrpl.biz] ...OK, Login ... Sending NCK code ... Trying NCK lock 7 ... Then if i try to Init Simlock with JAF the error is the same, but with jaf i can also Calc NCK, with no results and the log is: Imei: 35421603****** Version: SIMLOCK SERVER Provider: Retevision Movil Amena, Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 21403F, DATA=21403F Reseting LOCK Counter ... Imei: 35421603******** Version: SIMLOCK SERVER Provider: Retevision Movil Amena, Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 21403F, DATA=21403F There Is Solution for these 5800?? BR |
11-07-2009, 22:07 | #11 (permalink) | |
Freak Poster Join Date: May 2005 Location: italia Age: 55
Member: 144459 Status: Offline Thanks Meter: 67 | Quote:
solved please this problem ... thanks | |
11-08-2009, 01:40 | #12 (permalink) | |
Cheater -Don't Deal with him- Join Date: Nov 2007
Member: 635691 Status: Offline Sonork: 100.1592330 Thanks Meter: 137 | Quote:
please Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 | |
11-08-2009, 12:50 | #14 (permalink) |
Freak Poster Join Date: Apr 2006 Location: EARTH
Member: 259397 Status: Offline Thanks Meter: 76 | 5800 ulock prob i also face this prob ... but i solved myself..... two or three reason .... first.... just change logger and sx4 servers . in server setting.. and load nokia module with ufs interface then go imei and secuirty check pa sl2 option. and then adentify... after this press update splock... prob is 10000000000% solved this is my tested 10000000000% |
11-11-2009, 16:08 | #15 (permalink) |
Member: 192348 Status: Offline Thanks Meter: 6 | For me no change... also with cahen server the results is negative, with this log: Provider: Retevision Movil Amena, Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 21403F, DATA=21403F Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.10913, Date: 05-11-2009 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot(0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x190C bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending Certificate(0x1A20 bytes) ...OK Calculating NCK using security server ... Connecting to server[main.mxkey.biz] ...OK, Login ... WriteDevice failed: Failed to read/write device #pw+ e temporary una +1 # #pw+ vailable. +2 # #pw+ +3 # #pw+ +4 # #pw+ +5 # #pw+ +6 # #pw+ +7 # Sending NCK code ... Trying NCK lock 7 ... and then the error of the post up the second SX4 server is no good, because the connection isn't established... |
Unlock Nokia 5800 Show by Cyclone box problem ! | DTHmobile | Cyclonebox | 1 | 01-30-2010 17:07 |
Problem with unlock nokia 5800 | pyroz | MT-BOX | 1 | 01-12-2010 13:57 |
problem to unlock nokia 5800 | delchoni | MT-BOX | 6 | 12-18-2009 09:23 |
unlock problem in nokia 5800 | some_info2010 | Cyclonebox | 3 | 07-14-2009 12:57 |
Problem to Unlock Nokia 5800 | Olegas | BB5 Box by D.K. | 7 | 06-23-2009 21:37 |
