11-30-2012, 13:28 | #1 (permalink) |
No Life Poster Join Date: Dec 2008
Member: 934255 Status: Offline Thanks Meter: 63 | Problem writing rpl "sim lock corrupted" I have the rpl backup of this board. but when i try to write the rpl give error: TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Erasing CMT NPC ... OK Updating RF ...OK Updating BB ...OK Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: C086FB4E Using device: HTI, FW ver: 00.50, SN: 01006C67 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 17500210107202547F937836215527D950BD6732 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 2B2A191B54288A818699B64E68916FE1E6A8562D TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Prog.status for Asic CMT ... NOR: OK Updating PRODUCTCODE (0563417)... OK Updating PSN (KOG167957)... OK Updating HWID (2000)... OK Updating SIMLOCK ...error 0x1 Updating SUPERDONGLE_KEY ...OK Updating CMLA_KEY ...OK Updating WMDRM_PD ...OK Phone type: RM-240 (Nokia 6500s-1) SW version: V 59.60 21-11-08 RM-240 (c) Nokia Imei plain: 12345610654321-? Product code: 0563417 Battery voltage: 4864 mV, current: 52 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! why? |
11-30-2012, 14:19 | #2 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Here Is Your Problem CMT PAPUBKEYS is blank/erased. 1st Full Flash With Newest Version Then Write RPL Bkp Solved Your Problem........... BR. Arsalan gsm2000. |
The Following 4 Users Say Thank You to .::MASTER ALONE::. For This Useful Post: |
11-30-2012, 14:28 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Need to Erase this Phone, So Download Latest Firmware of same Product Code, Follow steps from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ Flash it & Restore IMEI & other Backup. BR, ZUBER |
11-30-2012, 19:58 | #5 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
I got it now, As you know Nokia 6500-S comes with 2 Security, 1st is SL2 & 2nd is SL3, Latest Firmware available for your Phone Product is Version 9.40, that is for SL2 Phone, Your Phone was Flashed with Customized Firmware for Nokia 6500-S Phone, that is Version 59.60 for SL3 Phone. So it can be resolve like this: -Need to Erase this Phone once again, -So Download Latest Firmware Version 9.40 of your Phone Product Code, -Follow steps from here: HTI On USB, what this box can do? -Flash it & Restore IMEI & other Backup. Best of Luck. BR, ZUBER | |
11-30-2012, 20:12 | #6 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | Ok. i try with other firmware and is ok now. but now i have other problem. the firmware that work is 12.35 but dont have portuguese language. after flash 12.35 i try to flash 10.00 with portuguese and tick onlye language but at the end the phone dont boot.... I flash again 12.35 and is ok. but i want to add language only..... |
