02-03-2010, 10:03 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: I.N.D.I.A
Member: 256247 Status: Offline Thanks Meter: 444 | Repair sd data in mx key MCU SW version: V 07.23 17-07-09 RM-436 (c) Nokia HW version: 1001 RFIC version: 064c0601 DSP version: ICPR72_09w17 LCD version: SHARP PPM version: V 07.23 17-07-09 RM-436 (c) Nokia A BT MCM version: 2222-143C Retu version: 15 Tahvo version: 22 Content Pack version: Content: a V 07.23 17-07-09 RM-436 (c) Nokia Product Info: Production serial number: DAP437599 Module code: 0203868 Basic production code: 0563951 Long production SN: 0 Serial Numbers: IMEI plain: 351962039391699 IMEI spare to net: 3A 15 69 02 93 93 61 09 IMEI SV to net: 33 15 69 02 93 93 61 49 F0 Other Info: Model : Nokia 7210 Supernova (Live) CS type : GSM900/GSM1800/GSM1900 BSI: 6.2 KOhm SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Backup already exist. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11893, Date: 26-01-2010 Product: V 07.23 17-07-09 RM-436 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending CustomLoader(0x596C bytes) ...OK Calculating RPL using security server ... Connecting to server[main.mxkey.biz] ...OK, Secure Login ... RPL saved to "C:\mobileEx\3.3\data\backup\BB5_351962039391699_S IM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: 351962039391699 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-03-2010, 10:49 | #3 (permalink) |
Freak Poster Join Date: May 2009 Location: Hazaribag Age: 35
Member: 1040838 Status: Offline Sonork: 123 Thanks Meter: 29 | SIMLOCK_DATA corrupted! Backup already exist. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11893, Date: 26-01-2010 Product: V 07.91 29-10-09 RM-495 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...Communication problem, please make retry. plese help sir............. |
02-03-2010, 12:43 | #8 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | here is 6300 usb fleshing erorr Library version: 1.0.0.11893, Date: 26-01-2010 Due to USB protocol limitation, certificate backup will be skipped. NPC_DATA is empty. WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.3\data\backup\RPL\BB5_3567960251784 8_PM.rpl" Processing file: rm217__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.50 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Nokia 6300 USB Generic detached. Device found: nmwcdc\Nokia 6300 USB Generic Nokia 6300 USB Generic ready. Nokia 6300 USB Generic detached. Device changed, found new Instance: nmwcdnsuc\Nokia USB Flashing Generic Nokia USB Flashing Generic ready. Nokia 6300 USB Generic detached. Device found: nmwcdnsuc\Nokia USB Flashing Generic Nokia USB Flashing Generic ready. Nokia 6300 USB Generic detached. Device found: nmwcdnsuc\Nokia USB Flashing Generic Nokia USB Flashing Generic ready. Nokia 6300 USB Generic detached. phon allways stuk in local mode like 6680 usb fleshing allways befor starting fleshing fix thisssssssssssssssssssssssssssssssssssssssssssssss ssssssssssssssssssssssssssssssssssss |
02-03-2010, 14:38 | #10 (permalink) |
No Life Poster Join Date: Jul 2006 Location: jambuser (sarod)_swaziland_uk Age: 40
Member: 317494 Status: Offline Sonork: 1000.1984 Thanks Meter: 187 | bro i m useing all box but for flashing i never best box hwk then uni for unloking and other perfomance for other tools is ok so no body can compare with hwk |
6300simlock repair error (solved) in Mx-key | WAJID PNR | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-17-2010 08:09 |
SD Auth in Mx-key Good news for mx-key user | muksforu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-28-2010 12:02 |
SD Auth in MX-Key! | jijeesh | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 74 | 01-28-2010 06:42 |
how repair SD CALCULETION IN HWK J.A.F MX KEY IT IS PROSIBAL ????? | ARIF GIGANI | Nokia Hardware & Hardware Repair | 4 | 12-23-2009 09:06 |
Any sd repair option in mx key like ub | shivram | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 12-11-2009 08:57 |
