12-03-2011, 15:21 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 332522 Status: Offline Thanks Meter: 28 | Repair SD NOT WORK Code: Phone type: RM-472 (Nokia N96-3) SW version: V ICPR72_08w35.1.1 22-09-08 RM-472 (c) Nokia Imei plain: 35677602055642-4 Product code: 0571025 Battery voltage: 4379 mV, current: 97 mA Language Pack: - not available. SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Phone version(11.101) outdated, selected version is: 30.033 Phone version(11.101) outdated, latest version on server is: 30.033 Imei net: 356776020556424 Version: SIMLOCK SERVER Provider: Telcel, C.A. , Country: Venezuela (Bolivarian Republic of) Counter: 0/3, 0/10 CONFIG_DATA: 7340400023927779 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=732123 [Colombia-Telefónica Móviles Colombia S.A. ] BLOCK2: 1=CLOSED(MCCMNC), DATA=21407F [Spain-Telefónica Móviles España, SAU ] BLOCK3: 1=CLOSED(MCCMNC), DATA=21402FBLOCK4: 1=CLOSED(MCCMNC), DATA=74000F [Ecuador - All] BLOCK5: 1=CLOSED(MCCMNC), DATA=33403FBLOCK6: 1=CLOSED(MCCMNC), DATA=70503FBLOCK7: 1=CLOSED(MCCMNC), DATA=70604FBLOCK8: 1=CLOSED(MCCMNC), DATA=71402F [Panama-Telefónica Móviles Panamá S.A. ] BLOCK9: 1=CLOSED(MCCMNC), DATA=71030FBLOCK10: 1=CLOSED(MCCMNC), DATA=71606FBLOCK11: 1=CLOSED(MCCMNC), DATA=73002F [Chile-Telefónica Móvil ] BLOCK12: 1=CLOSED(MCCMNC), DATA=72207F [Argentina-Telefónica Comunicaciones Personales S.A. ] BLOCK13: 1=CLOSED(MCCMNC), DATA=74807F [Uruguay-Movistar ] BLOCK14: 1=CLOSED(MCCMNC), DATA=73404F [Venezuela (Bolivarian Republic of)-Telcel, C.A. ] Latest software release for Nokia N96 is 30.033 Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0800000 Using device: HTI, FW ver: 00.24, SN: 00000000 Connection status: EHCI:HUB:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Phone type: RM-472 (Nokia N96-3) SW version: V ICPR72_08w35.1.1 22-09-08 RM-472 (c) Nokia ApeCoreSw: 11.101 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW |
12-03-2011, 15:30 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | try to old mxkey software your problem solve mobile x v 3.5/1.4and 1.3 |
The Following User Says Thank You to iftikhar_246 For This Useful Post: |
12-04-2011, 13:40 | #5 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | HI, the New Update 3.5 rev 1.5, work in automatic in Bus/ceck or Scan/Ceck, if u phone have need OLD Protocol, this select in Automatic, this function w/o problem, loock Here please: Code: Reading RPL backup ... Reading Secure Storage ... Reading Important data ... Reading SIMLOCK data ... Reading CERT data ... CMT Data : SYSTEM ASIC ID: 0000000100000226000xxxxxxxxC192101023000 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1D100217A45D0456C4E3xxxxxxxxxx446A0DE3F907 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 8669C77551AE128xxxxxxxxxxxD0C7CB3D3F44CC1 TransmissionMode: DDR&TX2 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Flash Imei: 35593xxxxxx784 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK SUPERDONGLE_KEY_DATA saved OK CMLA_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35593xxxxx784_BACK.rpl" Allumts |
12-04-2011, 20:52 | #6 (permalink) |
Freak Poster Join Date: May 2009 Location: venezuela Age: 32
Member: 1027249 Status: Offline Thanks Meter: 24 | This and more errors of the new version, is solved through this post: http://forum.gsmhosting.com/vbb/f550...error-1380660/ |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
wintesla doesnt work | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 14:51 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
