08-21-2012, 13:56 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: dunja
Member: 786607 Status: Offline Thanks Meter: 66 | restore rpl failed why SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Done. |
08-21-2012, 14:09 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, Which Phone you want to Repair? where is your Full Buscheck Logs? If want assist, don't edit Logs. BR, ZUBER |
08-21-2012, 14:28 | #3 (permalink) |
Member: 786607 Status: Offline Thanks Meter: 66 | here bro pls help finally EID Mabruk bro ............. Phone type: RM-504 (Nokia 5530 XpressMusic) SW version: V ICPR72_10w29_tube1 24-05-11 RM-504 (c) Nokia ApeCoreSw: V 40.0.003 Imei plain: 12345610654321-? Product code: 0573239 Battery voltage: 4788 mV, current: 129 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Latest software release for Nokia Lumia 800 is SW 1750.0805.8773.12220 |
08-21-2012, 19:17 | #7 (permalink) | ||
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
What you understand with this post of mine? Every time in this Thread, am asking for your Full Buscheck Logs: Starts from Mxkey version to Simlock info., reason is have to read any Error in Phone Logs for that we can solve it. Each time am asking for Logs, you post some unwanted. Or else without Logs, i have to delete your Thread for Spamming every time without Logs. BR, ZUBER | ||
08-21-2012, 19:47 | #9 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | What i want to see is like this Full logs of mine. Can check difference between both yours & mine. My Logs: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085DA85 Using device: HTI, FW ver: 00.50, SN: 00011D3F Connection status: UHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 01600105DD0D7F564E18F97B1A15405D7C338690 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Selected firmware certificate matched. Original Imei: 35420603787735 Original Product code: 0581437 Bluetooth ID: 0025CF5519F2 SIMLOCK PA identifier: [0] PA_SL Phone type: RM-237 (Nokia 3110c) SW version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35420603787735-9 Product code: 0581437 Battery voltage: 4689 mV, current: 62 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) MMC password: madhuri SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354206037877359 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Now understand or not. |
08-21-2012, 19:59 | #10 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | If u have a valid NPC and Simlock rpl backup of your phone then erase your phone (only eeprom not full erase), now write your phone Npc and simlock rpl data repair SD, and write pm area 1,309 with sx4 |
08-22-2012, 17:19 | #11 (permalink) |
Member: 786607 Status: Offline Thanks Meter: 66 | XKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C086FF92 Using device: HTI, FW ver: 00.50, SN: 010057F2 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 16E0000FE17E005284ACA65237F08F41FAEF0AD0 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF Selected firmware certificate matched. Original Imei: Empty Original Product code: Empty NPC_DATA invalid ! SIMLOCK PA identifier: [0] PA_SL3 Phone type: RM-504 (Nokia 5530 XpressMusic) SW version: V ICPR72_10w29_tube1 24-05-11 RM-504 (c) Nokia Imei plain: 12345610654321-? Product code: 0573175 Battery voltage: 4742 mV, current: 185 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
08-22-2012, 19:23 | #12 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi Bro., If you have posted Logs like this then answer must be in Minutes. BTW you have to buy RPL in this case. BR, ZUBER |
MCU EEPROM contents: failed | phr3ak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-12-2001 15:58 |
HEX for CLIP to restore Factory Defaults | X-Shadow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2000 15:59 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
