11-24-2009, 05:58 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | rev.3.3 WD2 flashing bug... But the phone is now DEAD!!!!!!!!!!!!!!!! Now i flash it agian ang saw the proccess... It only Flash PPM area, thats way it's so FAST... FIX it......... heres to LOG: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11443, Date: 23-11-2009 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 00C97682:2984DA7E ASIC type: 5 UEM Imei: 35455301010884 Flash Imei: 35455301010884 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35455301010884_BA CK.rpl" Processing file: RM51PE506140.32 as PPM [WD2 BT2,WD2 ALGORITHM] size: 4.50 MB Supported Ids: 0082, 1081 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 00C97682:2984DA7E Area [00000000-0000FFFF] erased in 0.469 s Area [02B00000-02EFFFFF] erased in 29.578 s Area [04600000-0466FFFF] erased in 3.985 s Flash programming ... Programming completed in 39.547 s File Processed in 1 min 33.031 s Flashing completed in 2 min 15.343 s Phone not responding ! Total time to process is 3 min 32.015 s Bugs,bugs,bugs,bugs,bugs........ |
7210c flashing error using hwk (i used 3.3 rev.1.7 fixed) | i-Fixed | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 03-27-2010 05:53 |
mx key new v 3.3 rev 1.7 fix cant flash dc4 | bharat_3013 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 03-24-2010 13:30 |
bug´s mx key 3.3 rev 1.7 | bvcell | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-22-2010 14:44 |
BUG platform DCT4.version 3.3 rev 1.3 | gileng | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 01-28-2010 05:07 |
MobiEX 3.2 rev 5.2 WD2 PPM Flashing | abellcell | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 16 | 10-10-2009 04:53 |
