07-15-2009, 08:11 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | rh-99 rpl problem u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008527B0A3BDA66 ASIC type: 11 UEM Imei: 35487502785572 Phone Type: RH-99 SW Version: V 5.91 27-03-09 RH-99 (c) NMP Imei plain: ??????????????-? Product Code: 0546862 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MF Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! Invalid UEM Data, backup will not be created. how can i fix this problem & which option i use please help ? power off after 28 sec |
