RPL write empty UEM - Help I have 1208 newly install UEM. How to write rpl in empty uem? Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.10913, Date: 05-11-2009 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001AEDD4:DA3BDA66 ASIC type: 11 UEM Imei: Empty Phone Type: RH-105 SW Version: V 5.80 14-11-08 RH-105 (c) NMP Imei plain: ??????????????-? Product Code: 0549920 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MR Language Pack: - not available. TimeStamp: 2008-11-21T10:39:14Z SW Version: 5.80 Variant Version: 001 ProductProfile: RH105_0549920_5.80_001.spr Simlock: 0549920_SimLockDataVerifier_vDCT4.sim Imei plain is invalid !!! Imei net: 00000000000000 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! Invalid UEM Data, No RPL backup will be made for this phone. ~ZubairArain~ |
use mx key.login mx loger click dct4+ imei and oter sloution this.....http://forum.gsmhosting.com/vbb/showthread.php?t=898887 |
