06-21-2011, 10:01 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: india
Member: 1012744 Status: Offline Thanks Meter: 67 | Help ANY member NOkia 7020a-2(RM-497) FLASHING ERROR ! HERE IS MX-KEY LOGS........... MXKEY Serial: [XXXXXXXX] - XXXXXX Driver: NMWCD, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Processing MCU file: rm497__10.00.mcusw [BB5,XSR 1.6] size: 24.33 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 109FF531 CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 000053FF CMT PUBLIC ID: 4C0BA67F02BB8CA42206C31FC9B2FFC5FC62D5E7 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 109FF531 Verifying communication to device OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35198904713422_CE RT.rpl" CMT PAPUBKEYS HASH: 57B0CD145768F65CDF89F47F1FAE61BF16EF7DD7 Storing certificate [NPC, CCC, HWC, RND, R&D] OK. Partitioning.... Partitioning complete Erase size: 31.88 MB CMT MuxOneNAND area [00000000-0001FFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 57B0CD145768F65CDF89F47F1FAE61BF16EF7DD7 (RAP Certificate 167 v.1) sent CMT UPDAPP block sent CMT MCUSW block sent CMT GENIO_INIT block sent Programming completed in 5.266 s Processing PPM file: rm497__10.00.ppm_mk [BB5,XSR 1.6] size: 7.33 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT MuxOneNAND area [02000000-027FFFFF] Flash programming ... Programming completed in 1.578 s Processing CNT file: rm497__10.00.image_mk_059B760_002 [BB5,XSR 1.6] size: 14.67 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 77.31 MB CMT MuxOneNAND area [02800000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 3.296 s Total time for flashing process(boot+erase+write) was 25.265 s Waiting for device boot up ... Phone not found, retrying ... like this image http://clip2net.com/s/10FZa |
