12-15-2010, 15:13 | #1 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 762520 Status: Offline Thanks Meter: 95 | Security test fail 3110 # SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1E2002080E947C5631156F183CCC41C7F93DFCF0 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Original Imei: 35683302715600 Original Product code: 0550573 Bluetooth ID: 0022FDF5D04F Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35683302715600-3 Product Code: 0550573 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356833027156003 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF AFTER WRITING PM ALSO ITS SAME CAN ANY ONE HELP ME SECURITY TEST FAIL |
12-15-2010, 15:18 | #2 (permalink) | |
No Life Poster Join Date: May 2007 Location: Gujarat,India
Member: 517102 Status: Offline Sonork: 100.1601229 Thanks Meter: 199 | Quote:
tick only 1 & 309 , supersd auth, write pm , bus check..... | |
The Following User Says Thank You to .::RanjitSinh::. For This Useful Post: |
12-15-2010, 15:28 | #3 (permalink) |
Member: 762520 Status: Offline Thanks Meter: 95 | Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 86 bytes written. - Key: 18, size 86 bytes written. - Key: 20, size 86 bytes written. - Key: 25, size 4 bytes written. - Key: 29, size 6 bytes written. - Key: 34, size 80 bytes written. - 308 skipped Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 4.532 s done but the problem is same |
12-15-2010, 15:45 | #6 (permalink) |
Member: 517102 Status: Offline Sonork: 100.1601229 Thanks Meter: 199 | Last edited by .::RanjitSinh::.; 12-15-2010 at 15:52. |
12-15-2010, 15:59 | #7 (permalink) |
Member: 762520 Status: Offline Thanks Meter: 95 | CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1E2002080E947C5631156F183CCC41C7F93DFCF0 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Updating CMT CCC ...OK Updating CMT HWC ...OK Certificate programmed successfully ! brother thanks for ur feedback but the problem is same |
12-16-2010, 05:18 | #10 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | give me buzz on ym ........i will solve your problem.... |
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post: |
12-17-2010, 00:46 | #11 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | no hardware issue. for sure it is regarding with rf-bb calibration. don't forget to share here your result on yahoo chat BR |
The Following User Says Thank You to gbluez For This Useful Post: |
12-17-2010, 05:18 | #12 (permalink) |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | it done sucessfully via team viwer (write rpl without npc and write pm with sx4) ...... |
12-17-2010, 13:48 | #15 (permalink) |
Banned Join Date: Dec 2009 Location: Bhutan
Member: 1178270 Status: Offline Sonork: 007 Thanks Meter: 18 | SIMLOCK valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! how to solve this problem ? 1. First of all u need good pm with SX4 ( do SX4/super SX4 after that pm1 and pm309 ) 2. if not solved than check CCC and HWC certificates How to repair CCC and HWC certificates ? backup RPL than open it in notepad there u will see NPC data after that CCC data and HWC data just replace CCC and HWC data with manole's uploaded clone RPL's ( of same model ) http://rapidshare.com/files/34542441...e_by_MxKey.zip Free File Hosting Made Simple - MediaFire 4shared.com - free file sharing and storage MEGAUPLOAD - The leading online storage and file delivery service 3. if still not solved than recover certificates ( go to service --> than imei & security --> than imei rebuild --> recover cert BUTTON ) 4. if still same than Repair SL REPAIR SD SUPER SD AUTH write PM1 and PM309 5. if still same than make RPL backup full erase than flash than rpl than Repair SL than SD repair than super AUTH than PM 6. after all these steps if still same than i am here for don't worry __________________________________________________ ____________ FOR SL3 LIKE 5130 , 6700c ,................. 1. SIMLOCK invalid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! Block1 : open Block 2 pen Block 3 : open in this case just do SX4 and than pm1 and pm309 2. SIMLOCK invalid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! SL data corrupted in this case u need Nokia RPL ( not supported by MXkey yet ) __________________________________________________ _______________________ PM FILES OF BB5 : just download them from this link and enjoy MEGAUPLOAD - The leading online storage and file delivery service try out this solution bro...............100% tested |
Security Code | dESiRE! | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 05-13-2011 22:17 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
SECURITY CODE | AWLABA | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 02-22-2000 23:38 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
