Old 07-18-2011, 06:48   #1 (permalink)
Hafiz ArslanAli's Avatar
Member: 820592
Sonork: 100.1590378
Thanks Meter: 327
SECURITY_TEST failed! by MXkey not solved.
hi
team i found Nokia 7210c in contact service
Sl data currepted aslo superdongle i have repair sl data & super dongle
MXKEY Serial: [FT SCR2000 0] - C0818C37
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Driver: UFS2XX, ver: 3.1.5.0, NTMP ver: 2.4.16.0
Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
Product: V 07.23 17-07-09 RM-436 (c) Nokia
Using cached productData[0C900118A3F05850B834F25A560523893C99FC28] ...
Calculating SUPERDONGLE using security server ...
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7
Completed in 15.453 s
RPL saved to "D:\mobileEx\3.5\data\backup\BB5_RM-436_359310021653803_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
but PM auth is not work
Calculating  using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Elapsed: 9.235 s (session timeout out after 3 second)
plz tell me what is problem? how to solve this??
Old 07-18-2011, 06:57   #2 (permalink)
~:Sujyot GSM Zone:~'s Avatar
Member: 48238
Sonork: 100.54361
Thanks Meter: 397
Please try to search first before making a thread
All possible solutions related to Contact service of SL1 and SL2 are defined already
Try to recover cert. this could solve your problem
WBR
Jyoti
Old 07-18-2011, 07:10   #3 (permalink)
-=Meltech09=-'s Avatar
Member: 1084363
Thanks Meter: 109
@Hafiz ArslanAli,,.
try this bro...
select online sx4 server from server list
tick load RFBB from server..
tick PMM Auth...if phone successfully authorized
click write...
Old 07-18-2011, 07:40   #4 (permalink)
Member: 756960
Thanks Meter: 48
SL Data Corrupted
Procedure:
-Open MX Key
-Select "Generation: BB5"
-Bus Check
-Tick Service/IMEI & Security/Simlock
-Tick "Update SpLock"
-wait until done
or this solution
problem:
contact service bcoz
of
----security testfailed
----sd invalid
----simlock data corrupted
ACTIOn TAKEN:
use ufc cable # 5 set 7.1k
---- sd invalid
hit imei& sec
hit imei rebuild
hit sd repair
--- SEC TESTFAILED
HIT rfbb from server
hit sd auth
wait for authentication
write done
---- simlock corrupted
hit imei&sec
simlock
put check on make simlock rpl
hit update splock
done
Old 07-26-2011, 04:44   #5 (permalink)
Member: 796109
Thanks Meter: 8
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35318303567075-8
Product Code: 0581437
Battery voltage: 4623 mV, current: 64 mA
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 353183035670758
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
Old 07-26-2011, 06:41   #6 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 523
write rpl without npc data
and
rapeir simlock
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
have nokia lock 2 solution by cable oskarcore Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-29-1999 22:49
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-22-1999 01:28
Page generated in 0.18248 seconds with 9 queries
