02-20-2010, 16:55 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: BD.UAE. QATAR SAUDI INDIA
Member: 99509 Status: Offline Sonork: Whatsapp +971508482353 Thanks Meter: 210 | see sir manole Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 05wk47v61 09-07-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0839.42.0.1 25-09-2008 RM-133 Using cached productData[15300010844F0254D81EC99B1A0C7F825132CD33] ... Calculating SUPERDONGLE using security server ... Completed in 16.734 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-133_359569012454626_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...error 0x1 |
02-20-2010, 16:58 | #3 (permalink) |
Member: 99509 Status: Offline Sonork: Whatsapp +971508482353 Thanks Meter: 210 | SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 359569012454626 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED |
02-20-2010, 17:01 | #5 (permalink) |
Member: 99509 Status: Offline Sonork: Whatsapp +971508482353 Thanks Meter: 210 | Backup already exist. Using device: J.A.F, FW ver: 01.B0 Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 05wk47v61 09-07-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0839.42.0.1 25-09-2008 RM-133 SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK Sending CustomLoader(0x50B0 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x3B0 bytes) ...OK Calculating LOCK data ...OK Receiving Unlocked PM, please WAIT ... OK Unlocked PM saved to "C:\mobileEx\3.3\data\backup\359569012454626_UNLOC KED_308.1.PM" Writing Unlocked PM ... OK Completed in 33.610 s Restarting phone ... Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! do init simlock after this result |
02-20-2010, 17:08 | #9 (permalink) |
Member: 99509 Status: Offline Sonork: Whatsapp +971508482353 Thanks Meter: 210 | Backup already exist. Using device: J.A.F, FW ver: 01.B0 Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 05wk47v61 09-07-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0839.42.0.1 25-09-2008 RM-133 ERROR: Missing SP BLOCK or PM corrupted ! |
02-20-2010, 17:09 | #10 (permalink) |
Member: 99509 Status: Offline Sonork: Whatsapp +971508482353 Thanks Meter: 210 | SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359569012454626 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED |
02-20-2010, 17:10 | #11 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Make this steps: 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model BR, Manole |
The Following 2 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2010, 17:14 | #12 (permalink) |
Member: 99509 Status: Offline Sonork: Whatsapp +971508482353 Thanks Meter: 210 | Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...error 0x1 Socket error (10051): Network is unreachable |
02-20-2010, 17:31 | #13 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Update SIMLOCK error 0x1 1.Backup RPL ( just in case ) 2.erase eeprom 3.Repair SUPERDONGLE and SIMLOCK 4.Factory Default 5.Super SD Auth + PM [1] & [309] 6.post result ps : always use last module update br, |
The Following User Says Thank You to Andra For This Useful Post: |
Hi MANOLE SIR 2day i bought MxKey i need konw something about it | ms_ahmed | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-05-2010 12:30 |
To Sir Manole...... | bernie_09 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-05-2010 11:54 |
PLEASE FIX This PROBLEM Sir MANOLE.. | TsambakolTeam | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-04-2010 12:16 |
sir manole pls answer SD AUTH | ELOY1024 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-04-2010 07:09 |
To Sir Manole and MobileEx team...... | genehack | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 09-18-2009 18:47 |
