03-01-2010, 10:57 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: in your hert
Member: 618615 Status: Offline Thanks Meter: 85 | server down Connecting to server ...OK, Login ... Connecting to server ...OK, Login ... Connecting to server ...OK, Login ... Connecting to server ...OK, Login ... Connecting to server ...Socket error (10060): Connection timed out Connecting to server ...Socket error (10060): Connection timed out Connecting to server ...OK, Login ... Connecting to server ...OK, Login ... Connecting to server ...OK, Login ... Connecting to server ...OK, Login ... Connecting to server ...OK, Login ... Connecting to server ...OK, Login ... Connecting to server ...OK, Login ... Connecting to server ...OK, Login ... i want to rpl for 1600 nokia |
03-01-2010, 12:36 | #3 (permalink) |
No Life Poster Join Date: Apr 2003 Location: INTERNET-INDIA
Member: 26488 Status: Offline Sonork: 100.1581233 Thanks Meter: 151 | yes i alao face same error.. ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0004 0005 [Fujitsu ] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00052CBB:2984DA60 ASIC type: 2 UEM Imei: 35626xxxxxxxx Connecting to server ...OK, Login ... BR, Saif. |
03-01-2010, 15:21 | #4 (permalink) |
Member: 26488 Status: Offline Sonork: 100.1581233 Thanks Meter: 151 | ok now working server done. ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0004 0005 [Fujitsu ] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00052CBB:2984DA60 ASIC type: 2 UEM Imei: 3562xxxxxxxxxx Connecting to server ...OK, Login ... Hello C0805C69, you have 1980 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\356269xxxxxxx.RPL " ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0004 0005 [Fujitsu ] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00052CBB:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-93 SW Version: V 6.40 12-01-07 RH-93 (c) NMP Imei plain: 35626xxxxxxxx Product Code: 0533199 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: AA Language Pack: English,Dannish,Norwegian,Swedish Imei net: 35626xxxxxxxxx Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN BR, Saif. |
Server down, I try to do an Z310 and connect server fail. | gsmnice | Seking Server | 2 | 04-29-2008 23:08 |
cannot connect to server - is server down? | hridaya | Cruiser Suite | 6 | 08-03-2007 20:01 |
Error on server side?? Server Down?? 14/June/2007 00:30 HS GMT | DJiCE | Universalbox | 2 | 06-15-2007 11:21 |
