05-05-2010, 05:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 608370 Status: Offline Thanks Meter: 89 | 3110c dead HWK LOG 1ST BOOT : C0,07 [Rm-237] [2.1.0.1] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 0B30010DF3087F56B83A6C63E39D39CBD867EC64 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898981-00006A21, Int NU48F256 CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1 CMT KSIG0 : C0E691EA16A7593A9BB28832D7312A39F7ED668D CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm237__07.30.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00020000-0007FFFF CMT NOR Erase Area: 0x00080000-000DFFFF CMT NOR Erase Area: 0x00100000-001FFFFF CMT NOR Erase Area: 0x00200000-0031FFFF CMT NOR Erase Area: 0x00320000-0105FFFF CMT NOR Erase Area: 0x01060000-01067FFF CMT NOR Erase Area: 0x01068000-0107FFFF CMT FLASH ERASE OK, Time: 01:28 DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_BLK_ERROR at: 0x008DC400, 03 ERR: CMT FLASH WRITE D_BLK C7012D0103CD000010000000F172, LN: 0x004000, Time: 01:01 Process Failed, Repowering Mobile MXKEY LOG Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8009(15-04-2010), 1.0.0.12756(15-04-2010) Processing file: rm237__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0B30010DF3087F56B83A6C63E39D39CBD867EC64 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D Storing certificate ...OK Erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.969 s CMT NOR area [000006C0-0001FFFF] erased in 0.360 s CMT NOR area [00020000-0007FFFF] erased in 2.844 s CMT NOR area [00080000-000DFFFF] erased in 0.359 s CMT NOR area [00100000-001FFFFF] erased in 0.469 s CMT NOR area [00200000-0031FFFF] erased in 7.265 s CMT NOR area [00320000-0105FFFF] erased in 37.860 s CMT NOR area [01060000-01067FFF] erased in 0.359 s CMT NOR area [01068000-0107FFFF] erased in 0.344 s Flash programming ... CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written. Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x008E0400, Result: 0010 Flashing terminated with error(s) in 2 min 51.484 s RX Buffer: C7012D0103CD000010000000F172 JAF LOG FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\rm237__07.30.mcusw PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\rm237__07.30.ppm_c CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\rm237__07.30.image_c_tr APE Variant file: NONE Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese Backing up CRT data... Setting FLASH MODE Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 89810089 <=> INTEL -> Type not in database CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\0000\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Reading CMT NPC certificate... Reading CMT VARIANT certificate... VARIANT CRT empty, skip save... Reading CMT CCC certificate... Reading CMT HWC certificate... Saved to C:\Program Files\ODEON\JAF\ProgData\35522003696246_CRT_backup _92555.rpl Backup CRT OK! Backing up SIMLOCK data... Setting local mode... Failed! Aborting! Failed to backup LCK... Manual mode selected, version can't be checked! Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101001101 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 0B30010DF3087F56B83A6C63E39D39CBD867EC64 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 191EC665DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\0000\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 89810089 <=> INTEL -> Type not in database CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\0000\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Operation took 0 minutes 7 seconds... Sending CRT data... Erasing... Operation took 0 minutes 49 seconds... Writing... Stage 1 Sending CMT HASH for NOLO Sending CMT HASH for KEYS Sending CMT HASH for PRIMAPP Sending CMT HASH for PASUBTOC Sending CMT PUB KEYS... Sending CMT HASH for UPDAPP Sending CMT HASH for DSP0 Sending CMT HASH for MCUSW Sending CMT HASH for PMM_CONF Sending CMT HASH for SBIF_CONF Operation took 1 minutes 59 seconds... Reseting phone... PPM: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\rm237__07.30.ppm_c Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101001101 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 0B30010DF3087F56B83A6C63E39D39CBD867EC64 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 191EC665DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\0000\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 89810089 <=> INTEL -> Type not in database CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\0000\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Operation took 0 minutes 7 seconds... Erasing... Operation took 0 minutes 17 seconds... Writing... Stage 1 Operation took 0 minutes 29 seconds... Reseting phone... CNT: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\rm237__07.30.image_c_tr Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101001101 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 0B30010DF3087F56B83A6C63E39D39CBD867EC64 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 191EC665DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\0000\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 89810089 <=> INTEL -> Type not in database CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\0000\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Operation took 0 minutes 7 seconds... Erasing... Operation took 0 minutes 22 seconds... Writing... Stage 1 Operation took 0 minutes 28 seconds... Reseting phone... Done! Total time: 4 Minutes, 49 Seconds DCT4/BB5 counter: 431 After flash processing... Waiting for phone to boot... Failed! Aborting! Great masters are requested how can i revive this phone? quick reply will be appreciated |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
