03-23-2010, 07:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Calicut Kerala India Age: 46
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | sim card rejistation faild after imei editing after imei editing phone is sim card rejistratioon faild and 123 secont after phone off what can i do pleas help |
03-23-2010, 08:22 | #4 (permalink) |
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 882E [ST M58LR128GU,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008F8C8A:2984DA60 ASIC type: 2 UEM Imei: 35366541046555 Connecting to server ...OK, Login ... Hello C08106F2, you have 2000 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35366541046555.RP L" ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 882E [ST M58LR128GU,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008F8C8A:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RM-166 (Nokia 6070) SW Version: V 04.22 24-05-07 RM-166 (c) Nokia. Imei plain: 35366541046555-6 Imei OTP: 35366541046555 Product Code: 0534580 Cellular System: GSM ASIC ID: 0x2142, type: 2 Ppm Id: I Language Pack: English,Portuguese,Spanish,French Imei net: 35366541046555 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: BC914B84D15C62F3 PROFILE_BITS: AD0D733052AE34B1 SIMLOCK_DATA corrupted! |
03-24-2010, 13:01 | #8 (permalink) |
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | i cant write og imei please chek below ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 882E [ST M58LR128GU,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008F8C8A:2984DA60 Trying to find patch position ...Ok, found in 9.375 s Not supported firmware. Error while processing command ! please give currect solution |
03-24-2010, 13:18 | #9 (permalink) |
No Life Poster Join Date: Aug 2007 Location: india
Member: 573120 Status: Offline Thanks Meter: 145 | update splock in ( sim lock ) using init simlock if it gives err then get all info backup rpl and downgrade it . coz if it ll dead then you can flash it with orignal firmware . |
03-30-2010, 07:53 | #10 (permalink) |
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | sir i cant flash below the detailes Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Boot error: 02 FF FF 72 UPP not responding ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Processing file: rm166__04.230 as MCU [DCT4,DCT4 ALGORITHM] size: 8.72 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143, 3161, 3160 Boot error: 02 FF FF 72 UPP not responding ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 1 min 38.968 s please help as soon as possible best regards |
1110i sim card registration faild | khanmobiles0003 | Nokia Digital Core Technology 4 ( DCT-4 ) | 18 | 10-31-2008 07:25 |
1112 sim card registration faild. | alamgarh | Nokia Hardware & Hardware Repair | 6 | 09-19-2007 13:08 |
6270 sim card ragistretation faild | aloksoni | Nokia Hardware & Hardware Repair | 3 | 09-05-2007 20:02 |
1110i show sim card registeration faild | aukonline | MT-BOX | 2 | 10-12-2006 12:00 |
