05-23-2010, 07:06 | #1 (permalink) |
Freak Poster Join Date: Feb 2010 Location: Balochistan
Member: 1239771 Status: Offline Sonork: 1591957 Thanks Meter: 314 | sir manole how to flash nokia 1616 |
The Following 3 Users Say Thank You to Gulzar Magsi For This Useful Post: |
05-23-2010, 07:23 | #3 (permalink) |
Major Poster Join Date: Jul 2009 Location: kolkata
Member: 1086792 Status: Offline Sonork: 1000.2 Thanks Meter: 10 | anybody tell me how can unlock???????????? 1202(RH112) by mx key....rh111 is successfully unlocked.............but rh111 is not detected by mxkey............. |
06-09-2011, 12:02 | #10 (permalink) |
Registered User Join Date: Oct 2004 Location: Tanzania Age: 47
Member: 86787 Status: Offline Sonork: www.sammy685344861 Thanks Meter: 31 | Thanx MX-KEY TEAM WELCOME TO THE WORLD Here we go: 1.GENERATION DCT4 TIK X-GOLD 2.PUT FILES MCU+PPM+ CNT 3.THEN CLIK BUTTON FLASH LOGS HERE: MXKEY Serial: [FT XXXXX] - XXXXXX Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing file: rh125_005.050 Downloading item CODE:hw_f11_rh125_r05.050.fls, num block: 3, size: 4.09 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 45.344 s Erasing area 0x00C60000-0x00E657FE ...OK Programming completed in 45.344 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.219 s Checksum verified (0x0554) Processing file: rh125_005.05ia Downloading item CUST:hw_f11_rh125_005.05ia.fls, num block: 1, size: 1.98 MB Erasing area 0x00210000-0x0040AAFE ...OK Programming completed in 44.141 s Checksum verified (0xFF85) Processing file: rh1250_nai05.05ia Downloading item CUST:hw_f11_rh1250_nai05.05ia.fls, num block: 1, size: 374.33 KB Erasing area 0x00EB0000-0x00F0CC3E ...OK Programming completed in 8.906 s Checksum verified (0xE3DC) Total time for flashing process(boot+erase+write) was 4 min 1.953 s Phone Type: RH-125 SW Version: V 05.05 24-05-10 RH-125 (c) Nokia Imei plain: 35538704938455-7 Product Code: 0590493 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Imei net: 35538704938455 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN DONT PRERSS CHECK BUS BEFORE INSERT: MCU+PPM+ CNT. Thanx mx-key team |
