03-20-2013, 15:47 | #1 (permalink) |
Freak Poster Join Date: Sep 2009 Location: not sure iam lost
Member: 1119981 Status: Offline Thanks Meter: 60 | sl3 bruteforce pc spec AMD 4.20 Quad Core CPU ATI Radeon 7750 4gb 4gb Kingston DDR3 1600mhz Memory DVD Drive Aero Cool Case 500gb Sata Hard Drive Asus Motherboard with 2 PCIE ports in case you need another VGA Board any help thanks |
03-20-2013, 21:29 | #2 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | Quote:
yes ok. but more heat | |
03-20-2013, 21:37 | #3 (permalink) |
Insane Poster Join Date: Sep 2011 Location: Hajigonj Chandpur Bangladesh Age: 34
Member: 1663170 Status: Offline Sonork: 100.1661551 Thanks Meter: 47 | Prossessor: Intel Core i7 RAM: 8GB HDD: 1TB I Have Use This PC In My Shop This Configer Ok For SL3 BruteForce Unlocking ?? |
03-21-2013, 14:25 | #10 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
6990 are obsolete and slow cards, also too much power hungy. (speed = ~ 2 x 2100MHash/sec, one card = dual GPU, power more than 400w per card) get 3 x 7970, which are faster, colder, and less power hungry, (speed = ~3350MHash/sec, single gpu, power = around 200W one) 3 x 3350M = ~10.150MHash/sec (10.1GHash/sec), max time per phone = 26h b.r. Alex. | |
03-21-2013, 23:13 | #12 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | Quote:
3x ati hd 7970=6144 stream processors ati hd 6990 up to 830MHz Engine Clock ati hd 7970 up to 925MHz Engine Clock you're right that faster 4-6 hours--- 3x7970 I calculate my per table----------------------------------------- GPU speed estimations for MD5/SHA1/Office 2007/WPA/WinZip/SL3 | |
03-22-2013, 18:46 | #13 (permalink) | |
there is, of course, more than stream unit number etc, it does matter the architecture of stream computing units, too. (and higher clocks are possible on 7970 card - up to 1200MHz) in short - I will repeat, 7970 cards = best performace per watt. the end. b.r. Alex | |
