Sl3 code not found Im using 1.8 revision After 4 days using the dictionary option reached 100% and code not found.... anyone having this problem ??? How to fix it??? |
now try to use "random salt" works for me |
Lets everyone who have "code not found" or hang at 99% write here activity/load of mainboard CPU and what kind of CPU use. I ask this because my CPU core2duo e7300 with crossfire cards is always load at 100% on both cores and this is my main bootleneck which make VGA activity unstable between 80-95% If any one use core2quad Q8xxx or Q9xxx I like to know his experience ;) Br. |
Thing is i was using revison 1.7 on random salt and everything was going great, now on 1.8 i wanted to test dictionary option in order to see if working 100% so in future i could split tasks between several computers..... seems dictionary option not working properly so i ask programmer to check this option and test it, it´s very important option to add, but it must be working.. Mobicom can u explain better what u mean ?? i have my both processors working at 98% with manual fan at 60% with 70º ... i can make 2600 jobs per salt with just one HD 5970 |
Ok i will check my system and tell u .... also are u using revision 1.8 ??? i think that maybe some kind of bug in this revision |
With 1.72 revision my GPU only worked at 48% each but codes where found.... so now with 1.8 GPU at 98% on each but in the end gives me code not found .......... So i think there´s some bug on revision 1.8 i tryed dictionary option, and now i´m trying random option Where are the moderators of this section to help us on this matter ??? No answer from support ??? Are we spending electricity for nothing ??? also loosing customers ?? |
Ok so now i checked system ... Intel core quad CPU 2,66 mhz CPU is working stable at 52% no problem with that.... |
had same prob, Supported Phone 1xHd5970 E8400 4gb Pc1333 ........ Little bit Oc No Code found with 1.8 Random Salt Selected second Attemp same System no OC, done @30% Other Phone work without problem with Oc but some not work. Done many of them ;) In my Case the Problem comes from Oc. Br |
5870 are always at 100% Quote:
How is your CPU e8400 load/used with 5970? |
Yes ,@ first try no Code found system was OC to 850Mhz @70° Second try @ 30% Code found System was not OC 725Mhz @60° E8400 Cpu Always on 100% with 1xHd5970 or with 2xHd5970 Oc or not Oc Regards |
I´m not using crossfire, just using in this computer 1 hd5970 CPU at 50% OC in gpu clock for 825 mhz and memory clock to 1100 mhz It gives me current speed 2600 hashes |
since CPU @ 4.1GHz is probably helping a lot :D cpu is a trash, but hey ... for that money, it's lot better than crappy Phenoms gpu usage is always at 98-99%, which is normal, cpu usage always at 100% both cores :D (when connected via RealVNC, it drops hashes/sec ... probably cpu start dying) Win7 Ultimate, 64bit, cpu E5300 @ 4.1GHz asus p5q-e p45 chipset, 355MHz FSB ocz ddr2 @ 1066MHz 2 x 5850 referent design (one from VTX, another from Power color, both Samsung GDDR, both identical) cooler master ultimate 750w b.r. Alex |
