05-09-2012, 05:02 | #1 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Hr, Rijeka
Member: 3149 Status: Offline Thanks Meter: 16 | sl3_online_logger_problem I sent the wrong read the log of the Nokia X6-00 IMEI: 352006040886500. The problem is that can not delete a log in the logger and set a new, correct log. logger says: Unauthorized fault Error processing your request(case id:0xCA04), imei or hash already exist on database ! Please delete this wrong log from server. It may be possible to return 125 Logs for unintentional errors? I sent PM to supporter, and no answer. Regards, Zlatko. |
05-10-2012, 16:48 | #6 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. delete all files from C:\Documents and Settings\Administrator\Local Settings\Temp folder manually & run registry repair software or which ever you have, but not sure. regards, |
05-10-2012, 17:05 | #7 (permalink) |
Member: 3149 Status: Offline Thanks Meter: 16 | Thanks for your reply, I will try, although I no longer needed, I bought one caculation on **** and now I'm waiting for codes. I could not wait for an answer dormant Supporter. best regards, zlatko. |
