03-17-2010, 22:08 | #1 (permalink) |
Crazy Poster Join Date: Mar 2010 Location: Rasht
Member: 1254480 Status: Offline Thanks Meter: 90 | solved imei 123456789? with mx-key nokia 5800 after flash its imei change to 123456789? & i had not any bkup. i try restor it with downgrade & upgrade but problem didn't solved. i try repair simlock with mx-key but after it phone only a vib and screen was black. flash it with ver40 and i was shocked!!!!!!!!problem solve after 5800 i try on 3110c and imei return to orginal imei and working 0Ook i try only 5800 and 3110 and i want try it on ur broken phone(with imei 123465789?) and post here result. br IRANIAN-GSM |
The Following 3 Users Say Thank You to PersianS For This Useful Post: |
03-17-2010, 22:23 | #3 (permalink) |
Member: 1254480 Status: Offline Thanks Meter: 90 | i cant show its log becuase phones are in good position and have imei. i test it and could not blieve it & post here to u test it and send its result |
The Following 5 Users Say Thank You to PersianS For This Useful Post: |
03-18-2010, 08:57 | #5 (permalink) | |
Member: 1254480 Status: Offline Thanks Meter: 90 | Quote:
whats ur phones model? -first repair simlock -then flash with last version i test this method on two phone and gave answer & i want u try it step by step and after it show us results br iranian-gsm | |
03-18-2010, 09:43 | #8 (permalink) | |
No Life Poster Join Date: Oct 2006 Age: 45
Member: 369678 Status: Offline Thanks Meter: 192 | OLD NEWS Quote:
03-18-2010, 11:56 | #13 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: Alaska
Member: 672931 Status: Offline Thanks Meter: 28 | brother PersianS, i think that possible or your lucky.. i have failed on 3110c with your step. here is final log Quote:
The Following User Says Thank You to OnyGSM For This Useful Post: |
03-18-2010, 12:04 | #14 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | imei reset can be from : PAPUBKEYS Phone ( RAP / RAPIDO ) not match with PAPUBKEYS Frimware if never erased before,just write with correctly PAPUBKEYS frimware then your IMEI will be normal. but some different case in N91 and N91 8GB, there is some complicated phone br, |
The Following User Says Thank You to Andra For This Useful Post: |
03-20-2010, 17:03 | #15 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
Guys dont get confused, he flashed his phone with wrong firmware before, that is why the IMEI changed to 123456789?, this is because the software can not read the NPC certificate correctly( the imei is not really changed but can not read correctly), and when he reflashed with the correct firmware, the IMEI is readed corectly. i experienced this problem with 3500c which is flashed with 6300 firmware, the phone boot up to nokia logo handshake and then shutdown. The IMEI is reported as 123456789? and when i flashed with 3500c latest firmware, the set is alive and work perfect. | |
The Following User Says Thank You to curvenger For This Useful Post: |
Can i repair 3110c with imei 12345610654321 with MX KEY please help | ntothel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 10-10-2010 18:17 |
contect service nokia-6300 how to solve with mx-key | akhtar.abbas | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-09-2010 13:57 |
I got a new problem with MX Key.Please solve my Problem. | caremobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 03-02-2010 19:38 |
Good News About bb5 contact service solved with MX key | erick_ponsel88 | Nokia Hardware & Hardware Repair | 7 | 02-18-2010 12:16 |
Succesfully imei rebuild 1650 with MX-KEY | gopidas | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-11-2010 13:05 |
