05-14-2009, 15:40 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Some Improvements to MXKey! I am starting this thread to let support MXKEY by telling minor problems. The very first problem I faced is: If a phone is flashing, and by mistake I click on Star Icon and shift to another module, flashing is stopped without any warning. At least, It should ask user that opening another module will terminate current process. Regards, Shadab Ahmad |
The Following 4 Users Say Thank You to [Shadab_M] For This Useful Post: |
05-14-2009, 19:00 | #4 (permalink) |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | One more: Check for Updates > Download and Install doesn't seems to work Even if it works, no progress or download indicator appears. Regards, Shadab Ahmad |
05-14-2009, 19:06 | #5 (permalink) |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | One More: It would be even better, if Model List automatically sort phone according to generation. If we select BB5 as generation, only BB5 phones should be listed. Now, we can select 1600 (RH-64) phone when BB5 is selected as Generation. It will cause Boot Error. Regards, Shadab Ahmad Last edited by [Shadab_M]; 05-14-2009 at 19:15. |
05-14-2009, 19:12 | #6 (permalink) |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | One More: It would be better if we can see Custom INI in Market List. Also, after selecting a phone model, its default INI should be loaded automatically. At the moment, we need to click on Load button. One more thing, Once we click on Market List, then we must have to click on this list to close it. It should close automatically by click the area on which we click it to open (just like a windows Combo Box Control). Regards, Shadab Ahmad |
05-14-2009, 19:24 | #7 (permalink) |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Radio Problem One More: Even if we can turn on radio by Phone Tests > FM Radion > Power On, we can tune or change anything there This should be fixed as we should be able to enjoy listening (only a joke) Regards, Shadab Ahmad Last edited by [Shadab_M]; 05-14-2009 at 19:25. Reason: Added Picture! |
05-15-2009, 06:57 | #8 (permalink) |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | One More: If once we have select Phone Model, Loaded Ini or Selected Flash Files, and then we do Bus Check, Phone Model goes blank and everything resetted. This happens to dead phones, bcoz MobileEx tries to read info from Phone after Bus Check. Causing all selected files to reset to blank. Please fix this. Regards, Shadab Ahmad |
The Following User Says Thank You to [Shadab_M] For This Useful Post: |
05-18-2009, 13:06 | #9 (permalink) | |
Freak Poster Join Date: Jun 2006 Location: KERALA , INDIA
Member: 287529 Status: Offline Thanks Meter: 62 | Quote:
BR Cellcraft India | |
05-20-2009, 01:37 | #11 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Philippines
Member: 230087 Status: Offline Thanks Meter: 373 | mine is a minor one only... I notice when I tried to get the erase address of 2600c & 2630 and try to use these addresses as erase files, it stopped at the middle of its operation.... What could be wrong there? The unit is alive, only hang but can load its info. Could it be that Mx-Key generated a wrong address for these models? Thanks for reply. |
05-20-2009, 21:53 | #12 (permalink) |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | One More: Sometimes, after we have aborted an operation and again need to do some operations, MobileEx fails to communication with phone. For example, can not read info even if phone is in Local Mode. In such case, we need to restart MobileEx and even Unplug and Plug again the Flashing Box. Br, Shadab Ahmad |
The Following 2 Users Say Thank You to [Shadab_M] For This Useful Post: |
Some improvement needed for microbox !!! | makroud | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 10-01-2009 13:28 |
some improvments if possibe pls | monsterpassword | SAGEM JTAG UNLOCKER | 0 | 11-29-2007 17:57 |
15 Jan 2007: Moto01 v1.36, some improvements | InfinitySupport | Infinity-Box | 31 | 01-19-2007 21:01 |
To the HWK Team, need some improvements in the last version. | The SAINT® | HWK | 55 | 06-19-2006 18:50 |
