02-03-2010, 18:20 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 326941 Status: Offline Thanks Meter: 16 | Still errors with DCT4 Flashing Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0035 [Samsung K5E5657ACK,256 Mbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_essr.fia [TIKU EIJA SSR] version: 4.76.0 revision: 0.7 size: 0x9868 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...Processing file: rm72_73_11003.800 as MCU [TIKU BT2,TIKU ALGORITHM] size: 10.14 MB Supported Ids: 1052, 2051 ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0035 [Samsung K5E5657ACK,256 Mbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_essr.fia [TIKU EIJA SSR] version: 4.76.0 revision: 0.7 size: 0x9868 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...flashing terminated ! Flashing terminated with error(s) in 1 min 10.812 s RX Buffer: |
02-05-2010, 13:54 | #5 (permalink) |
Junior Member Join Date: Oct 2004
Member: 85177 Status: Offline Thanks Meter: 7 | Uninstall the last update the following versions MXKEY folder and delete all the word "MXKEY" in the registry. Reinstall version mobileEx_setup_v3.3_rev1.0_fixed (20,091,125). Tested by me for DCT4 and WD2 while waiting for the latest updates to fix. |
The Following User Says Thank You to inamimel For This Useful Post: |
02-06-2010, 14:51 | #6 (permalink) | |
Member: 326941 Status: Offline Thanks Meter: 16 | Quote:
Code: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11446, Date: 25-11-2009 ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0035 [Samsung K5E5657ACK,256 Mbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_essr.fia [TIKU EIJA SSR] version: 4.76.0 revision: 0.7 size: 0x9868 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...Processing file: rm72_73_11003.890 as MCU [TIKU BT2,TIKU ALGORITHM] size: 10.14 MB Supported Ids: 1052, 2051 ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0035 [Samsung K5E5657ACK,256 Mbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_essr.fia [TIKU EIJA SSR] version: 4.76.0 revision: 0.7 size: 0x9868 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...Flashing terminated with error(s) in 1 min 6.891 s RX Buffer: JAF FLASHER INTERFACE disconnected. | |
still error unlock DCT4 plus with new version | Tubansel | Universalbox | 0 | 08-10-2007 03:56 |
V3r error with full flash file from support | bogdancirlogea | Smart-Clip | 9 | 05-21-2006 14:57 |
error with a920 flashing | falak | Motorola P2K (USB-Smart) | 1 | 03-27-2006 22:41 |
6230i emptyboards flashing - PPM still error with new 2.0895.exe | foony | Griffin | 10 | 06-13-2005 10:19 |
