Old 04-03-2010, 09:14   #1 (permalink)
Member: 118601
Thanks Meter: 200
N95 8g problem
i'm in trouble with N95 8G, the phone was working but always off after few minutes (3mn max). so i want to flash it or check if have another software pb. because i don't have FBUS cable at home (but at shop only) so i want flash it by usb. after "check" then conect usb cable then battery and power phone detected and install driver but soft don't detect in usb mode. so i click "check" again ....waiting for usb device....usb device not found....i remove phone and power it but no power dead! i think it is battery i change battery but nothing. so i bring it to shop and try it with FBUS cable and ufshwk but after "check" first boot ok boot 2nd boot error the same results with mx key. so what happen that phone can't power again and even can't be detect in FBUS mode?
Old 04-03-2010, 09:22   #2 (permalink)
Member: 51453
Thanks Meter: 729
flash your phone using fbus cable also use t.m.a adaptor so that it could give some supply when flashing using fbus.after flashing if phone is alive now do sd repair using mxkey that is why your phone tirns off in a couple of mins.hope this could help
br
Old 04-03-2010, 10:20   #3 (permalink)
rajesh_ch's Avatar
Member: 618404
Thanks Meter: 311
i think ur fone sd data is corrupted................
post.here ur fone log...................
Old 04-03-2010, 10:25   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
if you get
mean is , MXKEY not yet programming your phone
USB PC/LAPTOP still looking device driver and not reorganize yet in PC / MXKEY
how MXKEY kill this , that very strange ????
br,
Old 04-04-2010, 07:43   #5 (permalink)
Member: 118601
Thanks Meter: 200
yes very strange but notice that when i first insert battery phone was detected and auto install driver but "check" button not yet detected and boot usb device so i start the procedure again and again now no power on again. even on fbus cable (i use universal fbus cable) boot is not correct only fail when make second boot on hwk. when put battery in phone,i can see camera led few blinking for 1second and nothing after.
n95-8g problem flashing please help grts HWK 5 03-04-2009 18:26
N95 8g Problem guedes666 BB5 Box by D.K. 1 11-26-2008 19:55
N95 8G problem SVH Infinity-Box 9 11-15-2008 21:57
Page generated in 0.21527 seconds with 9 queries
