02-24-2012, 10:50 | #1 (permalink) |
Junior Member Join Date: Dec 2007
Member: 666208 Status: Offline Thanks Meter: 2 | Succes Flashing nokia 500 to belle :) Using device: USB ROM and HTI, FW ver: 00.50, SN: Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.73 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Processing MCU file: RM-750_111.020.0059_79u_prd.core.fpsx [BB5,XSR 1.6] size: 115.74 MB Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 400C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001040 CMT EM1 ID: 00001060 CMT PUBLIC ID: D8250000FFFB3C407BDE0FA834D4711A4B4DB9B2 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0232 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: D6091F6 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x1CC bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35974404483491_CE RT.rpl" CMT PAPUBKEYS HASH: F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 228.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT SOS+DECOMP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: F4C2F0A6 [] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 23.797 s Processing PPM file: RM-750_111.020.0059_17.01_APAC1_79u_prd.rofs2.fpsx [BB5,XSR 1.6] size: 46.84 MB Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 400C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108 Erase size: 59.25 MB CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 10.000 s Processing CNT file: RM-750_111.020.0059_U03.01_79u.uda.fpsx [BB5,XSR 1.6] size: 119.62 MB Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 400C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108 Erase size: 262.50 MB CMT FLASH,MuxOneNAND area [0E980000-1EFFFFFF] Flash programming ... Programming completed in 26.593 s Processing CNT file: RM-750_v0.017_APEONLY_prd.fpsx [BB5,XSR 1.6] size: 3.87 MB Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 400C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.875 s Total time for flashing process(boot+erase+write) was 1 min 18.719 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 500 USB Phonet, PORT_ID: 2C9D79B Verifying communication to device OK. Phone type: RM-750 (Nokia N00) SW version: V 79u_sr1_12w02_1 23-01-12 RM-750 (c) Nokia Imei plain: 35974404483491-9 Product code: 059L108 Battery voltage: 3815 mV, current: 296 mA ApeCoreSw: 111.020.0059 Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! THX FOR MXKEY TEAM |
The Following User Says Thank You to plashter For This Useful Post: |
