02-02-2013, 09:11 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: P.A.K.I.S.T.A.N
Member: 595389 Status: Offline Sonork: 100.1605422 Thanks Meter: 104 | successfully flash nokia 112-rm837 with mx-key MXKEY [FT SCR2000 0], SN: C0810F18 Using device: USB ROM and HTI, FW ver: 00.50, SN: 01000052 Connection status: EHCI:HUB:HUB:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.50 EBL version: Quantum_Bootloader_10.50_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 00EC 3012 - 23280002 [Samsung ] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 355184055xxxxxx IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35518405521068_ back.RPL" Processing file: rm837__03.32.mcusw Downloading item CODE:rm837__03.32.mcusw_ebl_psi.fls, num block: 4, size: 26 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.391 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.406 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.562 s Erasing area 0x40280000-0x41B3FFFE ...OK Programming completed in 35.750 s Checksum verified (0x770C) Processing file: rm837__03.32.ppm_m2 Downloading item CUSTackage_m2.ppm_ebl_psi.fls, num block: 1, size: 3.03 MB Erasing area 0x41BC0000-0x41EC7122 ...OK Programming completed in 4.515 s Checksum verified (0x1B4B) Processing file: rm837__03.32.image_m2_059P790 Downloading item CUSTackage_m2_059P790.image.fls, num block: 1, size: 15.13 MB Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 22.156 s Checksum verified (0xB5E4) Total time for flashing process(boot+erase+write) was 3 min 48.391 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-00 USB Phonet, PORT_ID: 274B6E1D Verifying communication to device OK. Phone type: RM-837 (Nokia 112) SW version: V 03.32 25-09-12 RM-837 (c) Nokia Imei plain: 3551840552xxxxx Product code: 059P790 Battery voltage: 4786 mV, current: 153 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: M2 Language Pack: - not available. Camera config: NI00CS00000401022F03, ver: 010.009 Imei net: 3551840xxxxx Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000004000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
The Following 2 Users Say Thank You to mahersaab For This Useful Post: |
02-02-2013, 09:36 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. You can post your Successful Story here also: http://forum.gsmhosting.com/vbb/f550...-mxkey-767051/ BR, ZUBER |
