02-06-2010, 10:21 | #1 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1170910 Status: Offline Thanks Meter: 76 | Successfully Repaired 3110c Security Test failed after SD Repair I repaired my sd and phone gone into Contact Service that is Security Test failed and i tried all the things best what i can do but no luck. (Sorry I dont have log for a SD Repair) I will show you the correct Path how to do that. 1.Take a Full backup of RPL, PM. 2.Download this File http://www.4shared.com/file/21598259..._failed_V.html 3.Open Your Original RPL file in Note Pad 4.Open Downloaded RPL file in Notepad and Copy only NPC Data in clone file. 5.Go to Imei and Security -> Imei rebuild ->Write Clone RPL 6.Go to PM Load Good working PM file and click Supe SD auth 7.Write 1 and 309 only and say no when it will ask to write simlock say No. 8.Now again do PMM Auth and Write PM 1&309 only and say no when it will ask to write simlock say No. 9.Go to Imei and Security -> Imei rebuild -> and click to recover Cert (Internet required) it will update your CCC and HWC with NPC. 10. After Completing Go to PM Make Super SD and Write only 1&309 and say no when it will ask to write simlock say No. and Your Done ( When i get another handset i will create a video.) Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35683302437161-3 Product Code: 0550573 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2008-11-12T10:12:21Z SW Version: 07.21 Variant Version: 015 ProductProfile: RM237_0550573_07.21_015.spr Simlock: 0550573_simlock.bin Imei net: 356833024371613 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following 7 Users Say Thank You to romeoluv56 For This Useful Post: |
02-06-2010, 10:33 | #2 (permalink) |
Member: 1170910 Status: Offline Thanks Meter: 76 | http://www.mediafire.com/?zydzqy2utzc working pm for 3110c |
The Following User Says Thank You to romeoluv56 For This Useful Post: |
02-06-2010, 10:55 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Now In USA Rim database Age: 47
Member: 248178 Status: Offline Sonork: 100.1579207 Thanks Meter: 323 | 10000% wroking thanx bro Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 3552xxxxxxxxxxx Product Code: 0544343 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35522xxxxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-06-2010, 12:44 | #6 (permalink) |
Freak Poster Join Date: Oct 2007 Location: indus
Member: 602248 Status: Offline Sonork: [email protected] Thanks Meter: 69 | Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35574302445391-8 Product Code: 0566914 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355743024453918 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-06-2010, 14:02 | #8 (permalink) |
No Life Poster Join Date: Mar 2008 Location: In My Shop, Bangladesh
Member: 733449 Status: Offline Sonork: 100.334100 Thanks Meter: 292 | Repair simlock> repair sd>SUPER SD AUTH> just click write (pm for 1 & 309) do not click pm auth. otherwise u see ''Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request'' tested for me on N70. |
03-20-2010, 18:00 | #11 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | yes already posted here 1. http://forum.gsmhosting.com/vbb/f550...0/#post5538567 2. http://forum.gsmhosting.com/vbb/f550...ml#post5593848 |
05-06-2012, 13:33 | #12 (permalink) | |
Junior Member Join Date: Nov 2010 Location: cape town south africa
Member: 1443428 Status: Offline Thanks Meter: 1 | Quote:
thank yu very very much lit worked on my phone | |
Nokia N96 Rm247 still security test failed after sd repair --Last Update -- | ABGSM | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-11-2010 11:01 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
Security Test Failed after SD Repair | adnann5 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-04-2010 06:58 |
Security test failed after sd repair.. | Rin2 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 02-03-2010 16:37 |
FOR those who have SECURITY TEST FAILED after SD repair | hasnain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-03-2010 15:13 |
