01-20-2011, 09:16 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 666540 Status: Offline Thanks Meter: 354 | successfuly converted 2610b rm87 to 2610 rm86 by mxkey Write good pm of rh 86 2610 then unlock...... put capacitors as shown in picture instead of make jumpers.... Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.(26-12-2010), 1(26-12-2010) ASIC ID: 0x3040 [UPP_4M ver: 4.1] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0087595AA3BDA66 ASIC type: 11 UEM Imei: 01104000xxxxx Phone Type: RH-87 (Nokia 2610) SW Version: V 04.91 27-02-07 RH-87 (c) Nokia. Imei plain: 01104000xxxxxx Product Code: 0540111 Cellular System: GSM ASIC ID: 0x3040, type: 11 Ppm Id: UB Language Pack: - not available. Imei net: 01104000xxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.x RPL saved to "C:\mobileEx\3.4\data\backup\01104000661015_BACK.r pl" Processing MCU file: rh86_87__06.70.mcusw [DCT4,DCT4 ALGORITHM] size: 8.64 MB Supported Ids: 3040 ASIC ID: 0x3040 [UPP_4M ver: 4.1] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0087595A:E68FDA60 Area [01000000-0101FFFF] erased in 0.516 s Area [01020000-018DFFFF] erased in 39.781 s Area [01EE0000-01FDFFFF] erased in 5.110 s Flash programming ... Programming completed in 1 min 40.766 s File Processed in 2 min 37.813 s Processing CNT file: rh86_87__06.70.image_mr [DCT4,DCT4 ALGORITHM] page size: 64 K size: 1.19 MB Supported Ids: 3040 ASIC ID: 0x3040 [UPP_4M ver: 4.1] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0087595A:C5A4DA78 Area [01B80000-01EDFFFF] erased in 15.610 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 13.437 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.188 s File Processed in 56.562 s Processing PPM file: rh86_87__06.70.ppm_mr [DCT4,DCT4 ALGORITHM] size: 2.17 MB Supported Ids: 3040 ASIC ID: 0x3040 [UPP_4M ver: 4.1] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0087595A:2984DA60 Area [018E0000-01B7FFFF] erased in 12.172 s Flash programming ... Programming completed in 25.031 s File Processed in 48.797 s Flashing completed in 4 min 25.172 s Phone Type: RH-87 (Nokia 2610) SW Version: V 06.70 16-11-07 RH-87 (c) Nokia. Imei plain: 01104000xxxxxx Product Code: 0540111 Cellular System: GSM ASIC ID: 0x3040, type: 11 Ppm Id: MR Language Pack: - not available. Imei net: 01104000xxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN after write pm Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.x ASIC ID: 0x3040 [UPP_4M ver: 4.1] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0087595AA3BDA66 ASIC type: 11 UEM Imei: 01104000xxxxxx Phone Type: RH-86 (Nokia 2610) SW Version: V 06.70 16-11-07 RH-86 (c) Nokia. Imei plain: 01104000xxxxxx Product Code: 0540044 Cellular System: GSM ASIC ID: 0x3040, type: 11 Ppm Id: MR Language Pack: - not available. TimeStamp: 2007-11-21T05:50:05Z SW Version: 06.70 Variant Version: 999 ProductProfile: RH86_0540044_06.70_999.spr Simlock: 0540044_simlock.txt Imei net: 01104000xxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to rajeshlehal For This Useful Post: |
03-15-2011, 16:56 | #4 (permalink) |
No Life Poster Join Date: Feb 2010 Location: kumasi-ghana Age: 32
Member: 1242667 Status: Offline Thanks Meter: 77 | next time dont try to flash de phone just do dis first try to write pm and second do factory settings lastly u unlock phone full service remember to do hardware filters on phone bye |
11-30-2011, 19:19 | #7 (permalink) |
Insane Poster Join Date: Sep 2006 Location: Lahore
Member: 342371 Status: Offline Thanks Meter: 73 | 1. Change the rx filter 2610b got it any other phone 2. Dont Flash 3. Write a good pm 2610 4. unlock |
The Following 2 Users Say Thank You to imranali2cool For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
