11-23-2009, 17:02 | #1 (permalink) |
Banned Join Date: Dec 2006 Location: inside of infinity best tool
Member: 411831 Status: Offline Thanks Meter: 215 | "SUPERDONGLE_KEY invalid!" after flash phone !!! i have Nokia 7210 Supernova. it was restart problem. now i flash with V 06.51. after flash SUPERDONGLE_KEY invalid! i 100% sure before flash it was all ok. now show this error Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 06.51 23-03-09 RM-436 (c) Nokia Imei plain: 3519xxxxxxxxxxxxx Product Code: 0566806 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3519xxxxxxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF i write backup rpl. which is mx-key saved b4 flash start. this is very big problem to me set is auto off after few second. need help please. |
11-23-2009, 17:50 | #5 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1009679 Status: Offline Thanks Meter: 166 | that only means in its restarting state prior to flashing Superdongle Invalid was already there............getz? now you need new rpl since your back-up was already damaged |
The Following User Says Thank You to Rabatu For This Useful Post: |
11-23-2009, 17:56 | #7 (permalink) |
Member: 411831 Status: Offline Thanks Meter: 215 | if i write backup show this RPL: "C:\mobileEx\3.2\data\backup\RPL\BB5_351xxxxxxxxxx x_BACK.rpl" Imei: 3519xxxxxxxxxx Restoring RF/BB DATA from backup ... Updating RF ...OK Updating BB ...OK Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000295 EM2 ID: 00000B22 PUBLIC ID: 1E80001964497D562064127100B9CED19F42E410 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 NPC verified Ok. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0566806)... OK Updating PSN (DTC186745)... OK Updating HWID (1000)... OK Updating SIMLOCK...OK Trying to update SUPERDONGLE_KEY ...error 0x0 Updating WMDRM_PD...OK Certificate programmed successfully ! Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 3519xxxxxxxxxx-0 Product Code: 0566806 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2009-07-20T08:46:24Z SW Version: 07.23 Variant Version: 012 ProductProfile: RM436_0566806_07.23_012.spr Simlock: 0566806_simlock.bin Imei net: 351xxxxxxxxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
11-23-2009, 18:00 | #8 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | You don't need to worry bro- SIMPLE, It was restart problem and now it is restarting only because of SUPERDONGLE KEY INVALID! I can say that it was SUPERDONGLE KEY INVALID! before you flash.If not then you have to prove by posting scanlog before flash. I flash many phones and did'nt ever encounter such kind of problem! |
11-24-2009, 18:30 | #10 (permalink) | |
Member: 411831 Status: Offline Thanks Meter: 215 | Quote:
really mx key damage this phone. i think no way without new rpl. | |
11-24-2009, 19:30 | #11 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Algeria-Cne Age: 47
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | if the software of MXkey show phone authentificated to superdongle message after writting RPL bakup that mean your superdongle key in this time is correct (RPL backup of mxkey contain simlock data). try to make info after wrriting RPL backup and post log here can you tel us what do you do after writting RPL backup? |
11-25-2009, 18:35 | #12 (permalink) | |
i try to write pm via sx4 authentic show superdongle data corrupt??? if u have solution plz share. | |
11-25-2009, 19:01 | #13 (permalink) |
Member: 1009679 Status: Offline Thanks Meter: 166 | try reset NPC then write your back-up PM then restore your back-up RPL i've been using MXKEY for several months especially in BB5 flashing. Doing some experiment destroying erasing all Flash Data and restoring all again with full success. Mxkey is very reliable when it comes with BB5. imagine again your phone keeps on restarting not because of HW problem but because of SW related problem...something corrupted there in which we never exactly knew which area. so Only possible if it was downgraded things like that. |
11-25-2009, 20:30 | #14 (permalink) | |
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | Quote:
bood luck | |
AP75 invalid PPF after flashing | ceedee | Infinity-Box | 9 | 01-22-2008 08:16 |
C62 : Why after flash phone power on but all "?????" | bestncheap | MT-BOX | 9 | 01-25-2006 13:37 |
7650 "bluetooth sysem error!" after flash | trustunna | Twisterflasher | 5 | 12-09-2004 09:15 |
