01-30-2010, 03:15 | #1 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1203722 Status: Offline Sonork: c0806008 Thanks Meter: 3 | SUPERDONGLE_KEY invalid! Problem SW Version: V 04wk47_m_v14.2.1 09-11-06 RM-36 (c) Noki Imei plain: 35761700837134-6 Product Code: 0524374 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357617008371346 Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN, DATA=23420F BLOCK 2: 1=OPEN, DATA=23594F BLOCK 3: 1=OPEN, DATA=23420F BLOCK 4: 1=OPEN, DATA=23594F SUPERDONGLE_KEY invalid This data damage MX can repair The MX all got stripe 2 times when then can repair SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. |
01-30-2010, 06:56 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | current version of mobileEx can't fix that phone if you don't have it's original backup. way to repair: 1. use other tool 2. wait for mxkey update |
The Following 3 Users Say Thank You to gbluez For This Useful Post: |
01-31-2010, 06:11 | #10 (permalink) |
Freak Poster Join Date: Jun 2006 Location: PAKISTAN
Member: 290794 Status: Offline Thanks Meter: 31 | try this backup the pm of hand set and then erase pm then click pm auth after that erase pm again and finally write your backed up pm again i hope it will be done try and post plz |
02-01-2010, 11:26 | #12 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | To repair SD with UB BOX, first need to buy 1 UB BOX at ~ 250 usd, then need to buy credits for this operation. Or he need to wait for MXKEY to come with FREE UPDATE BR, Manole |
The Following 3 Users Say Thank You to MANOLE For This Useful Post: |
SUPERDONGLE_KEY invalid! what can i do ?? | comp_new2006 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 18 | 05-08-2011 09:37 |
7120c SUPERDONGLE_KEY invalid,SIMLOCK invalid!done. | ...sewren... | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 03-25-2010 08:09 |
Help 7310c simlock superdongle_key invalid and invalid | nardisk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-29-2010 19:38 |
SUPERDONGLE_KEY invalid! | mobilewo | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 07-16-2009 20:35 |
