02-24-2012, 15:48 | #1 (permalink) |
Insane Poster Join Date: Nov 2011 Location: India, maharashtra, nagpur
Member: 1693062 Status: Offline Thanks Meter: 2 | 7210 contact service (ANSWERED) MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C086B8BB Using device: HTI, FW ver: 00.50, SN: 00015582 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 18500011C2B67D56A39A201756FA5F56DE1F1FCF ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Original Imei: 3////////////// Original Product code: 0572571 Bluetooth ID: 0025CF31A6B4 Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 3//////////////-3 Product code: 0566807 Battery voltage: 5000 mV, current: 0 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: NIMMIIIIRRFF094B2F01, ver: 002.010 SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! NOW I WANT STEP BY STEP SOLUTION.... |
02-24-2012, 20:09 | #4 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | - backup rpl just in case. > BB5 > Flash > Advance > Get Addr. select eeprom. don't mark safe erase, press erase. proceed: - BB5 > Service > Imei & Security > Simlock > Repair SImlock > click Repair SpLock - BB5 > Service > PM > Press Repair SD, follow on screen message - repair DCC if needed. |
The Following User Says Thank You to gbluez For This Useful Post: |
02-25-2012, 13:24 | #5 (permalink) |
Member: 1693062 Status: Offline Thanks Meter: 2 | bro one more 5130 contact service problem LOG Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 3///////////////-6 Battery voltage: 4688 mV, current: 97 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: NIMMIIIIRRFF0A021001, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
02-25-2012, 13:28 | #6 (permalink) |
Member: 1693062 Status: Offline Thanks Meter: 2 | I m doing these same steps - backup rpl just in case. > BB5 > Flash > Advance > Get Addr. select eeprom. don't mark safe erase, press erase. proceed: - BB5 > Service > Imei & Security > Simlock > Repair SImlock > click Repair SpLock - BB5 > Service > PM > Press Repair SD, follow on screen message - repair DCC if needed. erase flash ok then problem with doing repair sp lock showing this log SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C086B8BB Using device: HTI, FW ver: 00.50, SN: 00015582 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Using cached productData. PUBLIC ID: 04E000080E9D7D567348D2F0B8794EE7C3332624 PRIVATE ID: 465A38F17293527FC2009E79C0CA6E70A293C914 Updating SIMLOCK ...error 0x1 Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
02-25-2012, 15:27 | #7 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | backup full RPL, erase like master gbluez said, then flash latest version, write RPL from backup, Repair SD, write good PM, camera DCC repair, bus check then post logs. BR, |
02-25-2012, 15:34 | #8 (permalink) | |
Freak Poster Join Date: Apr 2009
Member: 1012278 Status: Offline Sonork: [email protected] Thanks Meter: 64 | this mobile chopatok yo receycal Quote:
02-25-2012, 15:37 | #9 (permalink) | |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Quote:
02-26-2012, 10:18 | #13 (permalink) | |
Member: 73565 Status: Offline Thanks Meter: 5,062 | you ask 7210 now you take 5130 to do my instruction man, don't waste your time and other's Quote:
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
unlock Service Provider Code for PrimeCo (USA) in 6185 Nokia Phone | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-11-2000 03:43 |
gsm service provider | sidou | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-30-2000 11:09 |
FREE SP unlock service | timxy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-22-1999 16:05 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
