12-26-2012, 13:52 | #4 (permalink) |
Freak Poster Join Date: Aug 2010
Member: 1380808 Status: Offline Sonork: askanwal Thanks Meter: 12 | nokia c1.00 showing error during flashing MXKEY Serial: [FT SCR2000 0] - C0811099 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UHCI:HUB:HUB:UFS2XX, ver: 2.0.0.0 , NTMP ver: 2.0.0.1 Module ver: 1.0.0.17841(12-07-2011), Library ver: 1.0.0.14214(25-10-2012) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 could not read flash id ! Task failed at (08000024)!!! Last RX buffer: 4E 02 03 00 |
12-26-2012, 13:52 | #5 (permalink) |
12-26-2012, 14:00 | #7 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
2. You are modified mobileex, crossed module is very buggy. 3. Support for other FBUS interface is ended. - get HTI, do your job with mobileex current version. | |
12-27-2012, 20:14 | #8 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000. | |
