09-22-2012, 12:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: AT YOUR EYES
Member: 747386 Status: Offline Thanks Meter: 30 | nokia 5030 rm 524 contect service MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0840F2D Using device: HTI, FW ver: 00.50, SN: 010016CF Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C40D82A3BDA66 ASIC type: 11 UEM Imei: 35627404881585 Flash Imei: 35627404881585 RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35627404881585_BA CK.rpl" Processing MCU file: rm524_005.010 [DCT4,DCT4 ALGORITHM] size: 2.37 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C40D82:2984DA60 Area [01000000-0100FFFF] erased in 0.781 s Area [01010000-0179FFFF] erased in 1 min 31.531 s Area [017A0000-017EFFFF] erased in 3.766 s Area [01F00000-01FDFFFF] erased in 0.093 s Flash programming ... Programming completed in 15.250 s File processed in 1 min 58.969 s Processing CNT file: rm5240_nai05.01ia [DCT4,DCT4 ALGORITHM] size: 184.53 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C40D82:2984DA60 Area [01750000-0178FFFF] erased in 3.015 s Flash programming ... Programming completed in 1.140 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.156 s File processed in 20.375 s Processing PPM file: rm524_005.01ia [DCT4,DCT4 ALGORITHM] size: 2.82 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C40D82:2984DA60 Area [01250000-0125FFFF] erased in 0.750 s Area [01260000-0174FFFF] erased in 59.735 s Flash programming ... Programming completed in 17.454 s File processed in 1 min 25.469 s Total time for flashing process(boot+erase+write) was 3 min 44.828 s Phone type: RM-524 SW version: V 05.01 23-09-09 RM-524 (c) Nokia Imei plain: 35627404881585-7 Cellular system: GSM ASIC ID: 0x2293, type: 11 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Master code: 5421776276 SIMLOCK_DATA corrupted! |
09-22-2012, 12:30 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Go to Service Tab > IMEI Security Tab > Simlock Tab > Tick Init Simlock & Click Update SP Lock, Will solve your Problem. BR, ZUBER |
