09-28-2012, 14:12 | #1 (permalink) | |
Freak Poster Join Date: Apr 2005 Age: 45
Member: 132735 Status: Offline Thanks Meter: 88 | sx4 cant connect server. Quote:
09-28-2012, 14:54 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-217.PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
09-28-2012, 15:33 | #5 (permalink) | |
Member: 132735 Status: Offline Thanks Meter: 88 | Quote:
resolved thread. | |
10-17-2012, 07:49 | #6 (permalink) |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | ı same problem rm-272 phone SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-272.PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. but not solve problem help me B:R |
10-17-2012, 10:36 | #7 (permalink) |
Member: 194907 Status: Offline Thanks Meter: 114 | Scanning local SX4 Card ... No SX4 Card found. SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.5 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out and Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-272.PM file, write error Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 16 (86 bytes) Warning: failed to write 1 - 18 (86 bytes) Warning: failed to write 1 - 20 (86 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 29 (6 bytes) Warning: failed to write 1 - 34 (80 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes help me please |
