Old 09-23-2009, 07:43   #1 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
SX4 server DOWN AGAIN????and AGAIN..
whats up team?????
server out this time???
i've try two server but same result...
Using device: J.A.F, FW ver: 01.B1
APE Data :
SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
ASIC MODE ID: 00
PUBLIC ID: DC5AC23A7DB779A19A0B8F40BC72DC0B9B74D0E7
ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
EM1 ID: 00000232
EM2 ID: 00000352
PUBLIC ID: 0B900105E18F4951E0DE01D161C0317410D4F79A
ASIC MODE ID: 00
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FCEA7B19D
SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
FlashID0: 0001 0002 - 0000 0111 [AMD NA] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
FlashID0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE
ALG [35]: OMAP1610 GBBM-1.8.1 ALG
ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000
Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908
APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
Original Imei: 35792700880590
Original Product code: 0530336
Bluetooth ID: 0015A0783F98
Phone Type: RM-84 (Nokia N70)
SW Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia.
Imei plain: 35792700880590-8
Product Code: 0524086
Language Pack:
- not available.
SIMLOCK seems to be valid
SECURITY_TEST passed
Imei: 357927008805908
Version: SIMLOCK SERVER VERSION 58
Provider: Hutchinson 3G (3), Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2342000000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN, DATA=23420F
BLOCK 2: 1=OPEN, DATA=23594F
BLOCK 3: 1=OPEN, DATA=23420F
BLOCK 4: 1=OPEN, DATA=23594F
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[mxkey.selfip.biz] ...-Server v2.4 hello 121.54.66.4
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
No SX4 Card found.
no regards..
Old 09-23-2009, 07:50   #2 (permalink)
Member: 144914
Thanks Meter: 27
server is ok..
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 06.01 16-01-08 RM-237 (c) Nokia.
Imei plain: 35308102568580-4
Product Code: 0514950
VariantId: S
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei: 353081025685804
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
No SX4 Card found.
Connecting to server[nkrpl.biz] ...MXKEY-Server v2.4 hello 121.122.88.195
SUPERDONGLE auth succeeded!
The Following User Says Thank You to express For This Useful Post:
Old 09-23-2009, 10:53   #3 (permalink)
Chevka's Avatar
Member: 82106
Thanks Meter: 1,208
@rico deep
try to change your SX-4 Server first !
you can do it right before you click "connect' to any interface, then go to options.
select server and click server list.
then you select SX-4 Server (there are 2 server available for this operation).
and so on...... you can do the rest
The Following 2 Users Say Thank You to Chevka For This Useful Post:
sx4 server down thungfanglie Universalbox 5 05-22-2009 19:52
Again And Again Server Down...!! Millo_6 UID - Box 0 10-10-2007 04:11
Twister support's down..again, and again, and again... cellcenter Twisterflasher 2 07-14-2006 09:05
Page generated in 0.13150 seconds with 9 queries
