Old 05-15-2010, 18:55   #1 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
SX4 server is working now?
Just now I am able to Do SX4, i cannot do that set before and was SD repaired already with Mxkey, but i can do that now, Friends why dont you try it and lets see the result if it worked for everyone now?
The Following User Says Thank You to curvenger For This Useful Post:
Old 05-15-2010, 19:08   #2 (permalink)
Member: 772651
Thanks Meter: 1,694
are you sure brother, i have been trying the same for about 15 days .. i never get success ... i am at home right now .. i will go early morining to shop and check .. if it happens then i wish cograts to mx-team .. by the way thanks..
Old 05-15-2010, 19:16   #3 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
For me it works, before i have two sets which is unable to do Sx4 and i kept it like that for more than 10 days already, now i repaired both of them.
Old 05-15-2010, 19:27   #4 (permalink)
Member: 772651
Thanks Meter: 1,694
ok br. early morning i will inform you .. *** bless me also .............
Old 05-16-2010, 03:22   #5 (permalink)
Member: 772651
Thanks Meter: 1,694
it is morning and i m at shop with this now i may get success but still
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 05-16-2010, 04:42   #6 (permalink)
net monitor's Avatar
Member: 600970
Thanks Meter: 89
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 byte
3110c CS?????
server not working
Old 05-16-2010, 07:41   #7 (permalink)
Member: 772651
Thanks Meter: 1,694
SIMLOCK_TEST passed
Section: 309
3110c CS?????
server not working
that is true brother , we can write PM fields 1 & 309 without SD REPAIR Auth. or PPM Auth . for that we need active service .. when we try we get
No SX4 Card found.
Old 05-16-2010, 08:19   #8 (permalink)
soy
soy's Avatar
Member: 220932
Sonork: 100.1592154
Thanks Meter: 110
scanning local SX4 Card ...
No SX4 Card found.
Old 05-16-2010, 09:01   #9 (permalink)
Member: 1203222
Thanks Meter: 53
Click Reapaer SD than super SD auth, Pm auth and write pm
Old 05-16-2010, 09:34   #10 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
not wrk for me
No SX4 Card found.
Old 05-16-2010, 10:00   #11 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
It is working 4 me now ..............
Old 05-16-2010, 10:38   #12 (permalink)
nomi_42us's Avatar
Member: 500844
Sonork: 100.1680109
Thanks Meter: 285
i also tried now and its working perfect
Old 05-16-2010, 11:25   #13 (permalink)
Member: 772651
Thanks Meter: 1,694
you all are dreaming and we still faces the same problem
No SX4 Card found.
Old 05-16-2010, 11:56   #14 (permalink)
Member: 1303410
I think you can try other internet access bro, in indonesian you can try speedy access... it's a good internet access..
br
felix
Old 05-16-2010, 13:11   #15 (permalink)
Member: 772651
Thanks Meter: 1,694
br
felix
now why the internet access question comes up .. it was not earlier we were using same internet access with previous versions also .. then why not now ...
actually i am thinking that mx-team is working and they may fix this problem soon .. this is on my part .. but when some members claims that server is working i get confused if server is working for other then why not for me ..
wintesla doesnt work ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 14:51
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.22622 seconds with 9 queries
