test failed please help kry problem (ANSWERED) SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 MXKEY Serial: [FT SCR2000 0] - Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: uhci:hub:hub:UFS2XX, ver: 3.6.0.0 , NTMP ver: 2.6.0.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) Product: V 07.30 07-05-09 RM-217 (c) Nokia. Using cached productData. PUBLIC ID: 07800104C7798C5643D42B2DE319EF690E80256F PRIVATE ID: B9B20E6CC7D3F82F3B454D0BEC8A688A9F02D548 E-FUSE: 025B2301 SEC ROM CRC: 40830040 Calculating using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify requestElapsed: 9.641 s (session timed out after 3 seconds) Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 202.88.248.25 SUPERDONGLE authorized :)! SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 Updating RFBB data ... Writing section 1... Error 0 Writing section 309... Error 0 Done. please check above problem please help best regards |
Maybe you use old Mxkey version. Use 3.5 rev 1.2 & - Open mobileEx.exe, Click "Synchronize Files" and Click "Update" when popup dialog showed. Try & post result |
ok thanks lot of thanks |
..add: and use HTI as interface. you will no need internet ;) BR |
