02-02-2010, 17:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: tunisia elmanar sfax
Member: 636518 Status: Offline Thanks Meter: 175 | there is any relation betwin sim lock problem and charger not supported?? |
02-02-2010, 17:04 | #3 (permalink) |
Member: 636518 Status: Offline Thanks Meter: 175 | Phone Type: RM-411 (Nokia 5220 XpressMusic) SW Version: V 05.63 12-01-09 RM-411 (c) Nokia Imei plain: 35366201037655-6 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353662010376556 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-02-2010, 21:57 | #5 (permalink) |
Member: 636518 Status: Offline Thanks Meter: 175 | sd repaired by mt-box but what about : "security test" ??? phone stilll show:"charger not supported"" Phone Type: RM-411 (Nokia 5220 XpressMusic) SW Version: V 05.63 12-01-09 RM-411 (c) Nokia Imei plain: 35366201037655-6 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST error ?!!? Imei net: 353662010376556 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-03-2010, 06:05 | #6 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Quote:
Hello Br, Here 5130c contact service successfully repaired with mxley, This solution same procedure as 5220 any bb5 models, Please watch and repaire your bb5 phones then post reply with successfully repaired phones and logs, Here is the link below, http://www.ziddu.com/download/698967...moved.rar.html http://www.sendspace.com/file/2n5rjh | |
02-03-2010, 13:00 | #8 (permalink) |
Member: 636518 Status: Offline Thanks Meter: 175 | Phone Type: RM-398 (Nokia 7510 Supernova) SW Version: V 06.65 04-06-09 RM-398 (c) Nokia Imei plain: 35639402380568-9 Product Code: 0569377 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2008-12-08T15:46:27Z SW Version: 03.80 Variant Version: 009 ProductProfile: RM398_0569377_03.80_009.spr Simlock: 0569377_simlock.bin Imei net: 356394023805689 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF ---------------------------------------------------------------------------------------------- --------------------------------------------------------------------------------- phone is ok and the surprise is that the phone is charging correctly....no charger not supported finally there a relation betwin sim lock corrupted and charger not supprted thanks to all... |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
3110c AUTO CHARGING AND CHARGER NOT SUPPORTED | alleti | Nokia Hardware & Hardware Repair | 1 | 10-04-2009 13:38 |
6280 sim problem and charger not supported.. | cronoszeu | Nokia Hardware & Hardware Repair | 6 | 03-23-2009 12:41 |
6233 Charger not Supported Any Solution ? | .:RoMeO:. | Nokia Hardware & Hardware Repair | 3 | 12-18-2007 20:05 |
is there is any manual to install red box | syrian | Redbox | 1 | 10-21-2005 22:05 |
