05-06-2012, 23:13 | #1 (permalink) |
Major Poster Join Date: Aug 2005 Location: ottoman Age: 47
Member: 171426 Status: Offline Thanks Meter: 10 | x3-00 security problem Phone type: RM-540 (Nokia X3-00) SW version: V 08.54 25-10-10 RM-540 (c) Nokia Imei plain: 35379******** Product code: 0580758 Battery voltage: 3796 mV, current: 100 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00IIIIRR0300000000, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Imei net: 353796********* Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN -------------------------------------------------------------------------- l repair sd Phone type: RM-540 (Nokia X3-00) SW version: V 08.54 25-10-10 RM-540 (c) Nokia Using cached productData. PUBLIC ID: 367002176A420049A7B5A589A497287E3F4B5336 PRIVATE ID: 2D47F20567E63522F778A1EE3E7458DC2720068F Completed in 0.125 s Updating SUPERDONGLE_KEY ...OK Writing RFBB data: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb\X3-00_RM-540.txt ... Writing RF settings to phone ...OK, finished. 15 Records found. Writing BB settings to phone ...OK, finished. 6 Records found. Done. nothing change phone start contact service |
05-06-2012, 23:40 | #2 (permalink) |
Member: 171426 Status: Offline Thanks Meter: 10 | IF ANY ERORS IN MXBOX OR MX KEY OR BB5 DONGLE TRY THIS PROCEDURE.... 1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) 7. erase pm again 8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert) 9. give full factory re l did not match |
05-07-2012, 06:00 | #3 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
try to apply FULL PM instead of 1 & 309 PM. good luck bro br | |
05-07-2012, 10:20 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Security Test Failed can be solve easily if follow some steps: Solution 1. Load PM from local RFBB & click Repair SD will solve. (If PM from local RFBB match) Solution 2. Load any full saved PM, tick section area 1,309 & click write will solve. (Make habit of saving full PM of working phones) Best Regards, ZuberChowdhry | |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
