06-04-2011, 12:36 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | 5130c flashing problem. (ANSWERED) Set is not flashing with fbus cable and also usb cable, please check log and tell me how can I solve that problem? With Fbus: [SIZE=1]MXKEY Serial: [FT SCR2000 0] - xxxxxxx Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 1.6.6.0, NTMP ver: 1.6.6.1 Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Processing MCU file: 9D0565B8_rm495__07.95.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 07A000023B1F7E567AF4C93AE517A13F13249FA3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT NOR area [00000000-000006BF] erased in 0.688 s CMT NOR area [000006C0-0001FFFF] erased in 0.125 s CMT NOR area [00040000-000BFFFF] erased in 3.109 s CMT NOR area [000C0000-0013FFFF] erased in 0.203 s CMT NOR area [00140000-0137FFFF] erased in 1 min 0.969 s CMT NOR area [01380000-0151FFFF] erased in 9.297 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 2 min 16.844 s Processing PPM file: 33A7D516_rm495__07.95.ppm_ssa_a [BB5,BB5 ALGORITHM] size: 6.57 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 07A000023B1F7E567AF4C93AE517A13F13249FA3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 9.640 s Flash programming ... Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout Error while programming [00] at 0x01684000, Result: 0010 Task failed at (0800001C)!!! Last RX buffer: C7 01 2D 01 03 CD 00 00 10 00 00 00 F1 72 With usb: MXKEY Serial: [FT SCR2000 0] - xxxxxxx Driver: NMWCD, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Processing MCU file: 9D0565B8_rm495__07.95.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: CBE0B3A CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 07A000023B1F7E567AF4C93AE517A13F13249FA3 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes Update Server code succesfully sent to phone. Stop there and no reponce . Last edited by madni shah; 06-04-2011 at 12:42. |
06-04-2011, 19:03 | #5 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: Makum, Assam, India
Member: 1540165 Status: Offline Sonork: 100.1606502 Thanks Meter: 29 | Quote:
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
