10-06-2010, 08:55 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Shaker-Telecom BaNgLaDeSh
Member: 1296389 Status: Offline Sonork: 100.1618052 Thanks Meter: 268 | Nokia 1616 falsh ok but no power (Answered) Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK Boot mode: CC EBL version: 10.19, Default_RAM_Bootloader Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] Processing CODE:hw_f11_rh125_r03.610.fls from file rh125_003.610 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 39.500 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 31.125 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.031 s Checksum OK (0xE49B) Processing CUST:hw_f11_rh125_003.61ej.fls from file rh125_003.61ej Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 31.391 s Checksum OK (0xCF63) Processing CUST:hw_f11_rh1250_nai03.61ej.fls from file rh1250_nai03.61ej Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 4.906 s Checksum OK (0xE74B) Flashing completed in 2 min 43.750 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RH-125 SW Version: V 03.61 29-01-10 RH-125 (c) Nokia Imei plain: 35823403451034-0 Product Code: 0587509 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: EJ Language Pack: - not available. "C:\Program Files\Nokia\Phoenix\Products\RH-125" folder created. Imei net: 35823403451034 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 2 min 52.625 s |
The Following User Says Thank You to saker2050 For This Useful Post: |
10-12-2010, 09:45 | #8 (permalink) |
No Life Poster Join Date: Aug 2006 Location: PAKISTAN SINDH
Member: 334225 Status: Offline Thanks Meter: 66 | this is big matter coming from x gold mobiles i have flashed many mobiles after flash done lcd goes faild i have checked many x gold mobiles but same problem lcd failed after flash why????????? |
10-17-2010, 13:42 | #9 (permalink) |
No Life Poster Join Date: May 2008 Location: kolkata
Member: 772386 Status: Offline Thanks Meter: 157 | bro check the light track, i tested many sets 5030,1661 etc i flash the phone but no power on, then i check light track and repair light track then set ok tested many sets, try and post result |
10-17-2010, 13:53 | #10 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Quote:
many xgold infineon processor phone's had this problem, i ddnt solved yet, kindly share if anyone solved, | |
10-17-2010, 14:31 | #11 (permalink) |
Freak Poster Join Date: May 2008 Location: LAGOS NIGERIA
Member: 773516 Status: Offline Sonork: 100.1583311 Thanks Meter: 69 | the phone is so simple to do i think out of 10 i will reture one to costomer back dat he cannot be repair.sometime u can not flash d phone it will not connect most of d problem is screen or d line of d screen is cut.like d one u flash and is ok when u flash then cheek d line of d screen and sometime they select screen dat will work d them. |
